PSA for those with Aftermarket Exhaust
Jacksonville, FL
2025 Explorer Plat 3L
#42
That's it? That's not bad. I had no idea but that seems easy enough.
4 Main Street, Wichita Kansas
Believe it or not, 3.25 cups out of mine. The driver side was 2.5 cups, mostly just yellow. My passenger side was sooty, which lines up with my passenger side having terrible exhaust tip dirtiness. Still not sure why.
Thermal 2.5”
Toadster
Folsom, CA
#44
3/16” is more than enough…either the front or lowest end of the muffler right at the seam and in the center.
would one in front and back be recommended? or just one hole is good enough?
has anyone confirmed the sound improvement/un-improvement after the water is drained?
MO
2026 ST AWD
#45
Toadster,
Borla instructions for Mustang mufflers (circa 2012 - some, not all mufflers) were to drill a 1/16" dia. hole about 1/8" from the weld seam at the inlet end of the muffler. The hole should be located on the centerline of the endplate bottom of the muffler. Borla's instructions had a note that only certain mufflers needed the drain/weep hole and it was recommended to call to confirm if a specific (Borla) muffler needed to be drilled.
edit/
Edited to correct hole location from bottom of the muffler to the bottom of the sideplate. I went back to the first page and started reading and came across post #31 by "THNX SVT" (thanks for posting that link to the Borla instructions).
/end of edit
HTH
Toadster
Folsom, CA
#46
Wow so on the inlet side - weird?!
Toadster
Folsom, CA
#48
Not really. Most cars have a slight rake so the inlet side is generally the low side. You want the hole on the low side.
I guess I just think the air is flowing backward but LOL
makes sense
