Single bolt diff brace, cold weather driveline vibrations
561
Or I don’t need it because I got a 2-bolt subframe on my 22. Look anywhere around here, not a ton of good reviews on the Steeda bushings.
you just proved my point by saying you don’t need it because you have a 2 bolt subframe … I’m talking about the Differential BRACE - and if you don’t think you need it think again
you obviously have no idea what you’re talking about and the fact you don’t even own a brace screams ignorance
Actually they’re well documented to fall apart when the flange gets hammered on hard acceleration. Steeda sends a different durometer bushing for those now…and they’re still not needed. Nobody needs to lock their diff down solid on their daily driver. Maybe don’t say people are ignorant when you yourself don’t know all the facts pertaining to those parts.
Nobody with a 2, actually 4 bolt, subframe needs a diff brace. Ford gave us all the bolts. JXB inserts and subframe lockout braces are great…but we don’t need a diff brace. Maybe you need to learn these cars better before you continue to chastise people.
561
Maybe you need to stay out of it Mr. Knowledgeable
Sounds like someone is butt hurt.
Unbroken is very knowledgeable and calling him names does nothing for your credibility.
561
#26
Can't sit down my butt is hurt :ROFLMAO:because Mr. Knowledgeable showed me - oh boy
Well, you were wrong and I gave you some more information…so there’s that. Whatever idiotic rage issues you have where you feel the need to insult everyone is between you and your therapist. Or your wall…whatever, tough guy.
You were still off base. Now you know more than you did earlier today.
And no, I will never stay out of it when someone is being bitchy for no reason.
561
Ouch showed me again - putting a brace on a weak point helps immensely regardless of whether you can afford it or not.
Two bolt subframe assembly bolts bend and break. One bolt subframe assembles bend and break. Put enough on it and it will bend or break, maybe you have the special Explorer with an indestructible differential, good for you Mr. Knowledgeable. I’m proud of you the way you handle everything and have Bunny’s who back you up you’re my hero, keep up the good work.
#29
Show me who has broke or bent the bolts on their 2-bolt rear subframe.
561
#30
You’re Mr. Knowledgeable do your research I’m not your Mammy.
#31
Funny how you cant point to any evidence and just resort to name calling cause you’re wrong.
It’s not a weak point on 4 bolt cars. I have seen zero instances of both rear bolts breaking and the diff dropping out. I’ve seen bushings get beat up and sag…which is why I said the JXB inserts, which I use, are good idea.
And I don’t really think I’m the guy you wanna get into the “if you can afford it” game with. Anyone that’s seen my build log would agree. But go ahead with your childish insults, punch a few walls and whatever else it is you do to make yourself feel like a man. You come off like a bitch…no matter how big and tough you think you’re typing. You’re impressing nobody.
561
#33
As reported by a GOOGLE AI search:
Steeda differential brace is highly effective at strengthening the 2020+ Ford Explorer differential, reducing movement, and preventing damage from broken bolts during hard acceleration. It increases rigidity, improves shifting, and reduces rear-end wheel hop, making it a key upgrade for performance and reliability.
  • Key Benefits: It distributes loads across the rear diff case, minimizing lateral movement and preventing failure.
  • Performance Impact: It provides a more connected "direct" feel and smoother shifts by keeping the differential in place.
  • Compatibility: Designed for 2020-2026 Explorer models (except 2.3L XLT AWD), including the ST.
  • Installation: Generally straightforward with basic hand tools, though it does not add to NVH (Noise, Vibration, Harshness
#34
Words of an expert.
Definition of expert is a drip under pressure.
No commercials needed. Thanks though.
Lots of opinions given here as absolutes. I see a lot of this on our forum. This isn't specific to this thread. What happened to the day when members would say, in my experience, I've seen this, or I like this one because, your experience may vary?
These conversations most often end the same way, with one member being louder than the other. One fanboy/toady or another jumps in to the fray to back one opinion, or the other, and at the end of the day the thread has answered little and has proven less.
I see a lot of opinions given and little evidence to support the opinions. Having witnessed one thing or the other even multiple times doesn't statistically mean anything with the sampling size we see here. I don't know of anyone buying all of these products to compare with the others and doing 500 launches with each to see they perform or hold up.
Reading it on the internet is worth exactly what you paid to do so. Life is good, be happy.
Steeda braces have broken
AWR braces have broken
FenFab braces have broken
ID Speed braces have NOT broken and is used on the currently quickest ST in the world. Livernois braces also have not broken. If results matter…there’s some results.
#38
First off I'm not a Steeda Fanboy or any other fan boy for that matter. I look for what I think is the best solution to a problem I might have. Having a 2025 ST with the single bolt diff and having bent the bolt I sought to find a solution. Looking at all the options to me the best solution is the Steeda with the Livernois running a very close second. Bought the Steeda cause I didn't want blue. Put the brace on and it was a simple install. Bought the Steeda 12.9 bolt and am waiting for the JXB insert and will install both. Hopefully ends my issues and I can get back to putting my foot in it. My opinion is simply this - if you own one of these vehicles you should consider a brace -period. Drive at your own peril otherwise.
Yet again, your opinion isn’t supported by facts. The facts are, not “all” ST’s need a diff brace. There have been no reported bolt failures on 4 bolt cars, even though you yourself claim there have been. You’re welcome to form your own opinions, you are not welcome to form your own facts.
Calgary, AB, Canada
My own real world experience with the Steeda Diff Brace, its a decent brace except that....
I have the Steeda diff brace installed. If I could go back and choose again, I'd choose Livernois or ID Speed Braces.
Reason: the Steeda diff brace doesn't allow access to the rear diff drain bolt. While the Steeda brace does have a center hole on the piece that attaches directly to the rear diff, the part of the brace with the bushings is offset of center of the diff when it is secured to the subframe. This offset does not allow for the diff drain plug to be removed without removing part of the diff brace.
Wish I'd known this before I purchased it. Steeda's website states: "An access hole is machined into the brace to retain easy diff fluid changes. No need to remove or uninstall the Steeda brace." This is not entirely accurate.
Anyway, I'll know better for the next ST.
I can also state that I've had no increase in NVH with the Steeda diff brace.
I just went on the Steeda site and noticed my review of their diff brace was removed. I didn't trash it but I did give it a lower rating due to the inability to remove the rear diff drain plug with the Steeda diff brace installed and I cited their inaccurate written description in my review. But is has been removed, in fact all reviews below 4 stars do not exist. Disappointed but not surprised.
