ZFG Racing Tune Review
561
#41
Buy the RTD and the credits from ZFG. Once everything arrives, install the app on your phone, create an HP tuners account, and select ZFG as your tuner. Then plug the RTD into your OBD port, sync it with the app, read your stock tune, and upload it. After that, submit a tune request on ZFG’s website to let them know your stock file has been sent.
ZFG will send you a base tune. Reconnect, load it, and perform the pulls they ask for while datalogging through the app. Upload the logs and submit the follow-up request. You’ll repeat this process a few times until they finish dialing in your tune. It’s much more customized than an off-the-shelf tune, and the RTD + app make the process very user-friendly. ZFG also has detailed instructions on their website. I did everything with my phone, no laptop.
When you order the RTD and credits, you’ll choose your tune type (Race, Performance, Daily Driver, or Tow). Think of Race as full send; each option lower is roughly a 20% step down. The Tow tune is designed to protect the vehicle while towing—do not tow on any of the other tunes.
Thanks so much for your response I will look into this, how many credits covers the whole process?
Gadgtfreek
Mobile, Alabama
2025 Explorer ST 4WD
Thread Starter #42
Its way easier than it seems. I have done this stuff plenty of times before, but the RTD4 and App work very well, and Adam is quick.
The ONLY thing that sucks is the data logging. You have to set it to log, wait for it to start, and then do the run he needs. It takes way too long for the service to start, but it is what it is.
561
#43
So will the cost of the package for $929 cover enough credits to cover the whole process...? I have to buy tires for my DarkHorse HP because Ford ships with Pirelli P Zero Trofeo R tires that are basically BRICKS in 40 degree or below weather VERY DANGEROUS. Soon as I pay for the new tires this will be my next project
Gadgtfreek
Mobile, Alabama
Thread Starter #44
Yep, you get that package with 4 credits, I think, and you are good. The driver mode tune thing may be more, but I just got the Performance tune and rolled with it.
My 2021 GT Premium came with Goodyears, and they sucked! Almost killed me in the rain twice. I went with Conti Extreme Contacts. But you still have to be careful with those in freezing temps, but rain is more a problem for me.
St. Louis
Yes, they are performance, summer tires. Designed to be run in temps >40°F.
I would be upset if my dark horse came with all-seasons.
Gadgtfreek
Mobile, Alabama
Thread Starter #46
I just kept a mental note: take it easy when it's cold.
#47
Yeah, those first few days in Sport mode were all over the place, but it’s mostly smooth now. That said, about one day out of seven the 10R still seems to have a ‘bad day’—maybe it just hasn’t had its coffee yet.
It acted out yesterday a couple of times with a hard shift, today its fine. But saw the same stuff with the 10R80.
My tranny has been very good in stock form since day one so I hope the tune settles down.
Gadgtfreek
Mobile, Alabama
Thread Starter #48
Mine actually were in both Normal and Sport. It's the best Ford transmission I've had yet, in OEM form. The tuning made sport mode do odd things, but it got better over the days. It reminded me of the 10R80 on the Mustang, cold in sport mode.
#49
Just sent in two data logs. There is some learning to the app and I lost a couple logs by pressing the stop button too many times. Odd my oil life indicator immediately went ot 0% after first load of tune. Also, the infotainment display is going up and down in brightness and the UI changes.
The first photo is how it is normally, it changes to the second picture on its own and the brightness changes. Lets hope that gets resolved.
Gadgtfreek
Mobile, Alabama
Thread Starter #50
I have not seen anything user-related with the tune load. That's weird.
#51
Ya I just pulled the base tune out and will wait for the revision.
Update: I pulled the base tune as I had audible detonation at low rpm under moderate throttle and will wait for a revision. I do not have absolute confirmation of this (we will see if it shows on logs) but likely as I reinstalled the factory tune and the knock disappeared. I understand many say the base tune is meant to be for a log but ZFG does not make mention of not running it until the next revision in my email communications from them. I am on Nevada 91 which is terrible so those in the CA/AZ/NV states should tread lightly on the base tune if you leave it installed before a revision.
Combatvet
I literally just got a call from ZFG because I submitted a call request earlier today. A very pleasant young lady walked me through my questions and discovered I hadn't completed one step, finished that step and now awaiting the base tune. Excellent customer service and care, I'm very confident with ZFG now. Peace of mind is bliss!
ETA: And just noticed my plugs have shipped. Merry Christmas to me!
Combatvet
My knuckles are still healing up from that job.
Already have an appointment with the Stealership to have them installed ($275.00), a wise man learns from others misery!
#55
It's my way of bonding. :LOL:
561
#56
What does anyone know of this set up is it worth $200 more over the S&B CAI ...?
FENFABrication High Flow Air Intake Kit V2 (2020-2025 Explorer ST)
Gadgtfreek
Mobile, Alabama
Thread Starter #57
Adam has a good post here on CAI's.
And yes, I am going to let my local shop do the plugs when I get them lol.
Combatvet
The sound is the main reason, the factory BOV makes all the right noises. Did I mention the sound!
Combatvet
Question for those who have their '25 tuned.
Did you throw a CEL? Mine threw a P0315 - Pending, Current, Permanent
Crankshaft Position System Variation Not Learned.
Did you experience hard shifts from 2-3, 3-4 at Wide Open Throttle in Sport Mode?
Wow did it wake it up, can't wait for the final tune.
Gadgtfreek
Mobile, Alabama
Thread Starter #60
Depending on throttle usage, you will have more firm shifts in Sport. Likely increased line pressure to reduce heat. It behaves more like a Mustang 10R80 now. I have learned that most of the time I dont need a lot of pedal to get moving, so I don't feel the hard shifts as much. Just getting used to the pedal with the new power took some time.I also don't punch the throttle, I more roll into the power if that makes sense.
No codes for me.
