Transmission Fluid Change - Should I or wait?
Suprawill1
Or do a double drain fill after driving around a bit in between if you like doing it yourself.
That kind of confuses me. If you drain and fill, drive around and repeat, how do you know you're not dumping the half you just put in?
Technically you dump half of what you put in yes but it mixes with the old fluid. You change 50% then drive around and do another change of 50% gets you almost 70% fluid change. Yes a transfer service gets near 100%. For those of us that maintain our own vehicles and don’t like needlessly shelling out money, this is more than adequate imo. I change every 25k so I’ve pretty much got fresh fluid all the time.
Suprawill1
Wish I had your diggs man! Got the tools and know how but no lift or appropriate area. I don't like needlessly shelling out that kind of money either. :-o
Makes car life a lot easier for sure. I got tired of working on my back in the driveway as a youngster so I bought a tool company later in life. Good thing too, the older I get the harder it is to crawl around. Heck my hands are sore for two days sometimes after a day of playing mechanic.
Suprawill1
I guess your next purchase would be a private, in home mechanic! (nodding head)
irontmp
Active Duty U.S. Navy
United States
BMW
#26
Mine was replaced at about 21000km (13,000ish mi) because the pan gasket was leaking; then I replaced all driveline fluids at about 50,000km (31,000ish mi), then again at 108,000km (67,000ish mi), so far no problems with any of the driveline housings. No harm in replacing fluids early/often - I saw enough examples over a number of years servicing cars what happens to fluids and vehicles that follow the “lifetime fill” schedule or some of the overly long manufacturer drain intervals Car maintenance…more than enough evidence for me to prefer to OVER-service rather than UNDER-service, and I have yet to blow an engine, transmission, or an axle on any car of mine by following my own schedule.
Yes, you should change the transmission fluid at 50k miles. The Explorer ST’s 10-speed transmission is known to develop issues over time, and fresh fluid can help prevent problems before they start. Waiting until symptoms appear is risky and could lead to costly repairs. Cost at a dealership is usually $300–$500, while independent shops may charge $200–$350. DIY can be done for under $150. Benefits include smoother shifting, reduced wear, and added reliability. Given the ST’s track record, it’s smart preventative maintenance.
irontmp
United States
BMW
#27
Lurking through Reddit posts, forum posts and FB Groups with the Exploder ST... Tons of owners are having transmissions problems well over 35k miles. I'm just about at 45k and next time when I go in for an oil change at 50k, I was thinking about replacing the transmission fluid and other bmw spares. Should I Or just wait until I experience problems? Also, What do you think the cost(s) would be? And potential benefits especially since this ST seems to be buggy or picky.
I’d definitely go ahead and change it at 50k. A lot of ST owners have had transmission problems pop up earlier than they should, and fresh fluid is cheap insurance compared to a rebuild. Dealers usually quote around $250 to $400 depending on whether it’s just a drain and fill or a full flush. The main benefit is reducing wear and keeping shifts smoother, which can help prevent some of the issues people complain about. I wouldn’t wait until there are symptoms because by then damage may already be done.
Nunya
Just did mine myself at 65k. I used 4 ramps, reversed up so the ramp wasn’t in my way. Harbor freight fluid extractor/dispenser and kevlar gloves. Trans shifts much smoother now and the fluid that came out was still red but it was pretty brown. I think it took right at about 6 qts with a new filter and pan drop. Dont trust the amazon filters, they don’t have a pickup mouth that extends down into the pan like the OEM. I personally dont trust others to properly do the job and get the fil level correct.
EDWYER
#29
How long did it take you?
Nunya
It was my first time ever doing trans fluid so i was extra cautious, i think like 4 hours. Next time will probably take me 2.
you’ll need a way to torque to inch-lbs. i had a 1/4” drive inch pound torque wrench but realized i didnt have a 1/4” extension for half the bolts after i was reinstalling. so took me forever to estimate the torque spec on half the bolts with some jank drill bit adapters that didn’t lock together… that and my first time checking level and waiting for temps to rise to 190. Realistically 2 hours next time i do it.
Mobile, Alabama
2025 Explorer ST 4WD
#31
People have been debating this for two decades, and somehow the argument still lives on. Do I believe in “100k-mile” transmission fluid? Sure — if you don’t plan to own the car anywhere near 100k miles, lol.
If you trade every 3–4 years (like me), don’t sweat it. If I still have this one at 50k miles, I’ll let the dealer handle all the drivetrain fluids. Until then… drive it like you stole it.
That said, there are plenty of vehicles well past 100k miles running OEM intervals with no issues. We obsess — and that’s okay. I also replace my serpentine belts around 50–60k miles. Go ahead, judge me.
EDWYER
#32
(y)
