Fen fab intake and p0236-0238 codes
2022 explorer
I installed my intake and in the process broke the map sensor on my intercooler no big deal replaced it with one from AutoZone still throwing codes and in limp mode. Could this sensor be bad that I just bought? I legit can’t drive my car now lol I need it fixed
Yeah, that’d be what those codes would correlate with.
Kyle5881
2022 explorer
So you think the sensor I bought is bad or not right?
Kyle5881
2022 explorer
A dealership near me has one I stock I’m gonna go buy and see because they’re literally nothin else wrong I know the lines are hooked up correctly the price difference is like $70 from advance auto junk part to ford part too hopefully that means something
Kyle5881
2022 explorer
It was advanced autos junk ass sensor the one I got from the ford dealership has it running normal. The people at the parts department said to buy oreillys parts out of all of them if i had too. Just a fyi
Combatvet
Disregard
Kyle5881
2022 explorer
Drove to work yesterday perfectly fine got in it after work threw the same code P0238 so idk what to do. There has has to be a vacuum leak somewhere I’m gonna try and find today after work
Combatvet
Are you sure it threw the codes because of the broken MAP sensor replacement?
Mine threw code when I drove in the rain, reset it with FORSCAN, then a couple of months later it threw a code when the temperature dropped significantly, FORSCAN reset again and all is well now.
Check your T-Fitting because I believe that is the major weakness with the system. Make sure there are no obstruction in it from the 3D printing. I also used worm gear hose clamps, purchased from amazon to tighten up the two ends.
Kyle5881
2022 explorer
So I ended up flashing my ecu back to stock and it fixed it and then reflashed back to tune and it’s running fine. I did go through and put clamps on all of the lines too but it was still going into limp mode after that until I flashed my ecu
561
Maybe it’s that goofy looking collaboration of what looks like my house vacuum pipes - spray painted red with a couple of mushroom caps on the end called a “FinFabGrabBag”
Kyle5881
2022 explorer
Well I’m flashing back to stock and taking it to ford it’s beyond me I can’t figure it out. I know it’s something fucking stupid too. Started my car to come to work went out noticed my rpms were at 5-600 and had that god for sakes wrench on my dash again.
561
I'm sorry my friend - we all do things in good faith, spend good money, and sometimes (seems more often than not - these days) shit turns out this way. I was joshing with ya' but honestly, I would never buy that setup just cause of the way it looks. I don't gives a rat's ass how it sounds and your prolly not getting any better gains then you do with an S&B or an AFE and neither of those make a whole lot of difference either. I wish you luck sorting it out keep us informed please ...?
Charlotte
You sure when you broke the sensor that whatever you did also didnt mess up the connector or wiring?
Combatvet
Spoken like a man that hasn't even tried the FENFAB, in my biased opinion it is the best intake that money can buy, even taking into consideration the weak 3D printed T-fitting. Don't knock it until you try it!
In all fairness, these codes dont seem to correlate with an intake. Something’s wrong sensor and wiring wise it seems, I can only guess though.
Kyle5881
2022 explorer
Thread Starter #17
That’s what’s in starting to think that I pinched a wire or slightly pulled one from the connector. Gotta pay to play I guess I know one thing I just want my car back lol
561
well - I’m not a man so…‍♀️
United States
Explorer ST
Who are you tuned with and did you ask them? My Fenfab was also throwing a code. Once I got my ZFG on there, the code went away. Might be because the codes are cleared when installing the tune, but it never came back.
Kyle5881
2022 explorer
Thread Starter #20
Just got off the phone with ford and I pinched a wire in the pigtail coming off the map sensor. $450 plus tax lol
