coachicks
Prattville, AL
Just took her home Thursday. Today and yesterday had it tinted 5% all around, new emblem city badges, color match bumper plugs, sto n sho quick release plate kit, auto stop eliminator and forscan to turn off double honk and turn on Bambi mode.
Which badge is this in the right picture? TIA
Autoworker
Cleaned it up inside and out. Put a coat of Meguiars Ultimate paste wax and 303'd all the trim. Should be ready for winter. IMG_0804.JPG
Dropped the oil again at 2579 miles. Will do again at 5K then 5K intervals thereafter.
Jake Speed Jr. covers it here:
I've always done 1k dump then 5K and every 5k thereafter but I added one additional after Jake made this video.
So mine will look like this:
1,000
2,579
5,000 with filter change then 5k intervals.
Mobile, Alabama
2025 Explorer ST 4WD
I'm swapping to Speed or Oil Analyzers next time. Blackstone is too unreliable in a couple of areas that I care about, like Fuel Dilution.
Jacksonville, Fl
I checked the transmission fluid and burned my arm in the process. Someone needs to make a dipstick kit. It was slight low, added 1/4 of a quart.
Jessup, MD, USA
What problem did this solve?
The stock transmission mount is soft and has some voids in it. This allows the driveline to move around a bit. This mount will help keep the transmission and driveline more stable, which should help shifts feel more firm, and ultimately put more power to the ground.
I also theorize that excess movement is what accelerates the downpipes and flexpipes cracking. Maybe this will help slow it down, or reduce it.
