10r60 fluid level
Nunya
I just did a drain and fill with a new filter. Ford recommends the fluid level be between 4.5 - 3 on the dipstick. But I know folks on this forum have said it should be at about 2.5.
Before I drained it, i checked the fluid level at 97C and it was at a 2 with the rear end slightly lower than the front end (Last serviced 30k miles ago by ford dealership). My garage is only a 1 degree slope and I didn’t feel it was worth the trouble trying to get it perfect. 200 miles After my service, my dip stick is reading about 1.8 at 100C with the car on the exact same slope.
Am I over thinking this or should I drain like 1/4 to 1/2 quart? Car drives great,
I live in colorado and I hardly ever drive on a flat road.
Thanks.
Dominican Republic
Ford Explorer ST 2021
3.5 ~ 2.5 for best performance
It should be 3-3.5, should be no lower then 3. Just checked mine today because it’s shifting weird again, and mines at 2.5. Once I fill it back to 3 it’ll be better.
W
Nunya
2.5 on the dipstick is more fluid than 3. 3.5 is lower than 3. I think you are confused
W
Nunya
Guess I’ll update for other people wondering, i left my fluid level where I had it about 1.8 and it’s been driving great. Downshifts as so much smoother and more predictable after drain and fill. Checked the fluid again after a few hundred miles and looks clean and red no bubbles i could see
I am confused, I was literally looking at a pic of the dipstick as I was writing this too. Dummy me. Meant “It should be 3-2.5, should be no lower then 3. Just checked mine today because it’s shifting weird again, and mines at 3.5. Once I fill it back to 3 it’ll be better.”
W
Nunya
It happens! These dipsticks are weird
The 6R80 in my 2010 EX had the same issue, it was a quart low and acting weird. I bought a universal dipstick from LMR and put it on and now I can check the fluid level under the hood like it should be.
After I paid 70 bucks for it, I found it on Amazon between 38 and 50 for the exact same thing and amazon says it will fit the 6R60/6R80, and the 10R60/10R80. I'm about to order a generic one from amazon and try it. If it fits, I'll buy another for the mustang which has the 10R80
W
Nunya
I don’t see any way the dipstick will snake down to the 10r60 plug location. There’s basically enough clearance for 2 fingers around it and above it is the floor pan. I would save yourself the trouble and look under there first. IMG_2200.jpeg
I circled the spot there. You can see floorpan directly above it.
Yeah, I had fun trying to check mine without a lift or ramps. Burnt the heck out of myself before figuring out how to contort my hand correctly to unscrew it since a wrench would literally take forever to loosen it.
W
Nunya
Yea that’s actually the most annoying thing why do they need so many threads LOL. I used harbor freight kevlar gloves worked amazing
I have a set of old school stick welding gloves I used on the 6R80. Its easy to get to, but the cat is right there.
South Carolina
Do you put anything on the gasket when installing a new on to the pan? (Aftermarket or OEM) I plan on getting a PPE pan so I’m just going to put a new gasket on.
No need. If you want you can wipe them with your finger wet with trans fluid.
W
Nunya
I just checked my gasket closely and wiped it clean with my finger. Ford says it’s reusable. Some people say you need to replace it but I reused it and have been under the car multiple times to check and it is still bone dry. I think it is really important to torque the pans accurately with the plastic pans. I bought a harbor freight inch-pound torque wrench and followed manufacture specs. Might not be as important with the metal pans.
W
Nunya
Actually does anyone know where to get the OEM gasket? I couldn’t find it online and the cheap amazon ones are rubber. I Don’t trust them at all
South Carolina
How did some of you break loose the transmission cap? Did any of you have to take heatshields off or something? I can get a wrench on it but not enough leverage. This is my first time trying to get the cap off. Thank goodness for Kevlar gloves lol
You can crack it loose with the car off and exhaust cool, but don't loosen until it's running. try hanging another wrench off the end of the wrench your using as a makeshift cheater bar to gain more leverage.
W
Nunya
Thread Starter #20
Thankfully the dealership topped it off before i bought it so it has been cracked open already. I broke it loose pretty easy with the car cold. It doesn’t need to be very tight, just 30ft lbs. no need to remove anything. And in case you are wondering, with the cap and dipstick out i was able to drive it up and down ramps (under all 4 wheels) In the garage without any mess.
