Appreciate everyone sharing their experiences here — doing research for my next build and found this thread incredibly helpful.
Had a ’22 Platinum that I sold for a different platform, now coming back to do a full build on a ’25 Platinum (converting it to ST specs like last time). Spent considerable time researching the diff brace landscape and wanted to share my findings — both to help others and get feedback from those further along.
Brace Comparison: Key Options for the Platform
ID Speed ($499)
• Most consistent praise across Explorer builds
• Engineered like a 4-bolt system
• Uses EPDM bushings for superior NVH control vs. poly
• Ideal for daily-driven or mixed-use builds
• No major complaints found during research
AWR Racing ($280)
• Excellent value option with solid design
• However, some concerning red flags:
• Marketing claims about police fleet use unverifiable
• “Lifetime warranty” contradicted by fine print (“racing use only”)
• Works well for many, but integrity concerns may be dealbreakers for premium builds
Steeda ($550)
• Multiple reports of excessive NVH
• Design appears too rigid for daily-driver comfort
• Documented mounting bolt failures under load
Livernois (SEMA 2024 release)
• Similar to Steeda design but not identical
• Uses premium ARP hardware
• Too new for real-world data
• Like Steeda, appears better suited for track use due to stiffer design
Bottom Line
• Go ID Speed if budget allows – best engineering, clean install, solid support, minimal NVH
• AWR works but proceed cautiously – great price, questionable marketing
• Avoid Steeda unless prioritizing track times over comfort
• Livernois is unproven – worth monitoring but not recommended (yet) for daily builds
Troubleshooting NVH or Whine After Brace Install
Something that kept appearing across platforms — Mustang, Camaro, Trackhawk, Explorer:
Braces rarely cause noise. They reveal it.
Installing a brace replaces soft factory bushings with solid mounts, transmitting more vibration and sound into the chassis. Early wear in your pinion bearing, gear mesh, or carrier preload — previously masked — suddenly becomes audible.
If You Hear New Noise After Install
1. Don’t assume the brace is to blame
• Remove the brace temporarily. If noise disappears, the problem was likely already developing inside the diff.
2. Log noise patterns
• Speed (45–50 mph, 58–62 mph are common problem zones)
• Throttle input (accel vs. decel)
• Temperature, road surface, etc.
→ Helps differentiate gear whine from bearing drone or bushing resonance.
3. Send diff fluid for analysis
• Use a lab like Blackstone
• High iron = bearing wear
• Brass/bronze = gear or thrust washer wear
→ Confirms preexisting issues.
4. Check for Ford TSBs
• Some Explorer models have known diff/pinion issues
• The brace might simply be surfacing a documented problem
5. Verify brace torque and alignment
• Over-tightened or misaligned installations can cause vibration
• Confirm clean seating, correct torque spec, and no diff preload
6. Use chassis mic or mechanic’s stethoscope (if available)
• Helps isolate whether sound originates from diff, half shafts, or elsewhere
• This approach saved several users from misdiagnosing axle issues as diff problems
Final Thought
• If a brace makes something louder — it may be doing you a favor.
• Better to hear early-stage wear now than experience a $3000+ failure later.
• Whether you’re building from scratch or doing a conversion like me — understanding what the brace isn’t doing is just as important as knowing what it is.
If your findings differ or you’ve got first-hand experience that adds to (or challenges) any of this, I’d love to hear it — always open to sharpening the insights.
