Rear differential brace Steeda, Livernois, ID speed
Ford Explorer ST
Help me decide. While they're very similar I'm torn. Help me choose
E
Ford Explorer ST
ID Speed over both of those. Don’t fall for the “bigger is better” hype.
Didn't even have them on the list. Now you gave me more options LOL Thank you for that
The Livernois one at least looks good, Steeda one sucks. What exactly makes the Livernois unit inferior to the ID-Speed?
I’ve said a thousand times these double braces aren’t needed. There’s no reason to lock the rear diff down solid on a daily driver. The ID Speed brace was actually engineered to work like a 4 bolt car.
E
Ford Explorer ST
You're swaying me more and more to the ID Speed. Not that its a bad thing LOL
What about on a 2-bolt rear subframe car?
I like the JXB inserts for 4 bolt cars…they do work and do exactly what they claim. Unfortunately I have some NVH increase and removed them but many haven’t had that experience.
Do you think they’ll do the job alone without a diff brace with stopping the bushing from failing? I remember Tyler’s old car (which was a 2-bolt) bushing failed after quite a few launches he does.
He had issues after literally thousands of launches. Bushing failures on 4 bolt cars can be counted on half of one hand. Mine looked perfect at over 110K when I installed the JXB inserts.
Iowa
2022 Ford Explorer
I have the Steeda. I actually don't have it connected because of NVH issues. Although it may not be common to the Steeda as I am sure there would be more posts about it. I get a very noticeable humming noise that seems to be transmitting from either the rear diff pinion or carrier bearings. Not noticable without the brace though and thus not enough for Ford techs to replicate it.
Pompano Beach, FL, USA
We’ve had a lot of very satisfied customers with this upgrade—while I can’t share exact sales numbers, I can say the response has been outstanding since we introduced it. I’m happy to help you with a Steeda unit and can offer preferred forum pricing. Feel free to reach out to me directly at [email protected].
butt_yodel
Iowa
I'm on my 3rd rear diff and 2nd driveshaft and the dealer can't find this noise. Mine's at 45 mph and 58-62 mph, accel and decel, but louder at decel. Throwing a carrier bearing at it, don't know what else to try. AWR brace on mine is almost like a stethoscope to an underlying issue. I did some research on the FB group and this is an issue with all braces for a very small number of people. My '22 was dead quiet, in the '23 I can't cover the noise with the radio.
Iowa
2022 Ford Explorer
Mine all started last fall. I did have my brace on for about 3-4 months and had not issues. Right about 95,000 miles. I do second it when it starts making the noise nothing covers it up.
2022 Ford Explorer Platinum
Appreciate everyone sharing their experiences here — doing research for my next build and found this thread incredibly helpful.
Had a ’22 Platinum that I sold for a different platform, now coming back to do a full build on a ’25 Platinum (converting it to ST specs like last time). Spent considerable time researching the diff brace landscape and wanted to share my findings — both to help others and get feedback from those further along.
Brace Comparison: Key Options for the Platform
ID Speed ($499)
• Most consistent praise across Explorer builds
• Engineered like a 4-bolt system
• Uses EPDM bushings for superior NVH control vs. poly
• Ideal for daily-driven or mixed-use builds
• No major complaints found during research
AWR Racing ($280)
• Excellent value option with solid design
• However, some concerning red flags:
• Marketing claims about police fleet use unverifiable
• “Lifetime warranty” contradicted by fine print (“racing use only”)
• Works well for many, but integrity concerns may be dealbreakers for premium builds
Steeda ($550)
• Multiple reports of excessive NVH
• Design appears too rigid for daily-driver comfort
• Documented mounting bolt failures under load
Livernois (SEMA 2024 release)
• Similar to Steeda design but not identical
• Uses premium ARP hardware
• Too new for real-world data
• Like Steeda, appears better suited for track use due to stiffer design
Bottom Line
Go ID Speed if budget allows – best engineering, clean install, solid support, minimal NVH
AWR works but proceed cautiously – great price, questionable marketing
Avoid Steeda unless prioritizing track times over comfort
Livernois is unproven – worth monitoring but not recommended (yet) for daily builds
Troubleshooting NVH or Whine After Brace Install
Something that kept appearing across platforms — Mustang, Camaro, Trackhawk, Explorer:
Braces rarely cause noise. They reveal it.
Installing a brace replaces soft factory bushings with solid mounts, transmitting more vibration and sound into the chassis. Early wear in your pinion bearing, gear mesh, or carrier preload — previously masked — suddenly becomes audible.
If You Hear New Noise After Install
1. Don’t assume the brace is to blame
• Remove the brace temporarily. If noise disappears, the problem was likely already developing inside the diff.
2. Log noise patterns
• Speed (45–50 mph, 58–62 mph are common problem zones)
• Throttle input (accel vs. decel)
• Temperature, road surface, etc.
→ Helps differentiate gear whine from bearing drone or bushing resonance.
3. Send diff fluid for analysis
• Use a lab like Blackstone
• High iron = bearing wear
• Brass/bronze = gear or thrust washer wear
→ Confirms preexisting issues.
4. Check for Ford TSBs
• Some Explorer models have known diff/pinion issues
• The brace might simply be surfacing a documented problem
5. Verify brace torque and alignment
• Over-tightened or misaligned installations can cause vibration
• Confirm clean seating, correct torque spec, and no diff preload
6. Use chassis mic or mechanic’s stethoscope (if available)
• Helps isolate whether sound originates from diff, half shafts, or elsewhere
• This approach saved several users from misdiagnosing axle issues as diff problems
Final Thought
• If a brace makes something louder — it may be doing you a favor.
• Better to hear early-stage wear now than experience a $3000+ failure later.
• Whether you’re building from scratch or doing a conversion like me — understanding what the brace isn’t doing is just as important as knowing what it is.
If your findings differ or you’ve got first-hand experience that adds to (or challenges) any of this, I’d love to hear it — always open to sharpening the insights.
ID Speed ($499)
AWR Racing ($280)
Steeda ($550)
Bottom Line
Final Thought
AWR is a perfectly good brace for 1-bolt cars, it doesn’t do as good as a job as the ID-Speed for 1-bolt cars. For 2-bolt cars, since the AWR is asymetrical it has a weird torsional effect with the left bushing. I don’t like it for 2-bolt cars but for 1-bolt cars it does the job if you’re on a budget.
That weird torsional effect you mention happens even more on the one bolt cars. The first videos showing it were a one bolt car. **** it’s hard for me to type that…they’re 3 and 4 bolt, not 1 and 2. lol
https://www.facebook.com/share/v/19gcBMsj9r/?
Oh dang you’re right, didn’t realize it was that bad. That’s horrible.
