Rear differential brace Steeda, Livernois, ID speed
Charlotte
2024 Explorer ST
Seems folks shit on the Steeda , but I have it along with the JXB insert and whoosh bolt on my one bolt and works great. Steeda has changed the mounting bolts to the subframe bracket so maybe that helps with the earlier reports of those bolts snapping on hard launches?
Sometimes I can detect a slight gear hum sound from the rear off the gas and slowing down at a certain gear/speed. Not 100% sure it is the brace or bushing or neither as I haven't removed them to find out. Doesn't bother me.
butt_yodel
Iowa
I'm on my 3rd rear diff and 2nd driveshaft and the dealer can't find this noise. Mine's at 45 mph and 58-62 mph, accel and decel, but louder at decel. Throwing a carrier bearing at it, don't know what else to try. AWR brace on mine is almost like a stethoscope to an underlying issue. I did some research on the FB group and this is an issue with all braces for a very small number of people. My '22 was dead quiet, in the '23 I can't cover the noise with the radio.
Upgraded with the JXB carrier bearing today. Noise didn't get any better or worse. I can definitely feel the driveshaft now, though. I'd imagine that's expected and doesn't bother me much.
Co
2025 St
Steeda on my 25. No complaints no noise. I think it’s a quality piece.
Minneapolis
2021 Ford Explorer ST
I can't seem to find the answer to this question: does the ID Speed differential brace come with the grade 12 bolt for the 1 bolt rearend I have in my '21? Or do I need to order the bolt too?
You need to order the bolt too.
Massachusetts
2023 ST
I'd say for my daily driven stocker, i'm leaning towards the ID Speed brace just for the EPDM bushing and lessened likelihood of NVH.
Minneapolis
#27
Thanks man. Possible silly question but I'd rather ask and know for sure...the JXB diff bushing insert will also work with the ID Speed brace, correct? (as well as any other brace I would assume)
Minneapolis
I completely agree. That's why I'm getting the ID Speed too, plus it seems to be regarded as the best one in an all-around sense. The fact that it's a couple hundred bucks more or whatever seems pretty inconsequential to me in the grand scheme of things and how much money I/you/we will be putting into these kickass trucks. Even if that money is only car payments and fuel. In my case I will for sure be doing many bolt-ons, probably FBO's sooner than later. And since this ST is fairly quickly going to become my all-in-one vehicle where I daily drive 50-75% in it, use it 100% for errands, building supply store trips, etc, as well as the new permanent tow vehicle for our 19' Lance camper, yeah I'm getting the best diff brace.
I went with AWR brace but in reality, can't even remember the last time that I launched mine. Generally speaking my romps on hwy on ramps or just some occasional WOT's in 2-4th.
#30
Yes, the bolt and insert won’t interfere with any diff brace at all
New Hampshire
My 2 cents, I have a 2 bolt SF with AWR brace, JXB inserts and the 12.9 bolts from whoosh, Also no NVH.
ggrant3
Davie, FL
'25 Carbonized Grey Explorer ST
#32
I just installed the ID-speed/CPe and I haven't noticed any NVH at all.
Calgary, AB, Canada
My own real world experience with the Steeda Diff Brace, its a decent brace except that....
I have the Steeda diff brace installed. If I could go back and choose again, I'd choose Livernois or ID Speed Braces.
Reason: the Steeda diff brace doesn't allow access to the rear diff drain bolt. While the Steeda brace does have a center hole on the piece that attaches directly to the rear diff, the part of the brace with the bushings is offset of center of the diff when it is secured to the subframe. This offset does not allow for the diff drain plug to be removed without removing part of the diff brace.
Wish I'd known this before I purchased it. Steeda's website states: "An access hole is machined into the brace to retain easy diff fluid changes. No need to remove or uninstall the Steeda brace." This is not entirely accurate.
Anyway, I'll know better for the next ST.
I can also state that I've had no increase in NVH with the Steeda diff brace.
I just went on the Steeda site and noticed my review of their diff brace was removed. I didn't trash it but I did give it a lower rating due to the inability to remove the rear diff drain plug with the Steeda diff brace installed and I cited their inaccurate written description in my review. But is has been removed, in fact all reviews below 4 stars do not exist. Disappointed but not surprised.
2025 ST
#34
I noticed zero change in NVH with mine.
Catmonkey
Louisiana
#35
Something worth mentioning is that Steeda offers their differential brace with two different bushing options. I've used their products in a lot of other applications, and this is something offered over various product lines. Their black bushings have a durometer rating of 95, which is pretty hard core and is likely to transmit more NHV then their red bushing that have an 80 durometer rating and are quite a bit softer. The latter of course has more deflection, but still a lot less than the stock rubber bushings. If you have the black bushings and getting unexceptable levels of NHV, you might ask to purchase the softer bushing and see if it resolves these issues, or at least minimizes them. We all have different expectations on ride quality and what we think is acceptable, but I'd bet most should be using the red bushings. The videos I've seen of the stock differential without any of these mods look pretty disturbing. Adding a tune and bolt-ons and it would seem it's only a matter of time before you break something.
#36
You’re referring to the pinion bushings, and you don’t need those and I wouldn’t want them either (they’re fail prone). The diff brace is all you need to truly fortify the 1-bolt rear subframe, everything else isn’t necessary just does little improvements to the way it feels or launches if you do it a lot.
Catmonkey
Louisiana
#37
No, I'm not. There is an optional bushing for the differential brace too in a drop down box on the order page. They use a hard and soft bushing on the pinion bushing too, but list it under different links.
https://www.steeda.com/steeda-555-8141-explorer-rear-differential-brace
Massachusetts
2023 ST
#38
ARC
Oak Lawn, IL, USA
2022 ST Black
#39
I did AWR brace and the JXB insert 68k and no problems yet, and I drive mine harder than most, tuned on E50.
#40
