Hull, GA, USA
If you kept the 22” setup would you have gone with a 40 tire or continued with the 35? Not sure if a 285 would be too narrow? Just wanted your take on the different sizes available. Thanks
Thread Starter #1,382
I’d never put a 305/40/22 on a lowered ST. It’s asking for rubbing issues. Now if a 305/40/21 existed it would be perfect for my new wheels but it doesn’t exist outside of one model of snow tire. I personally don’t like a 285 on a 10.5 wheel but plenty do…that’s a personal preference.
Hull, GA, USA
Took it apart and painted the outer ring. I tried to wrap it but quickly figured out that’s not a talent I possess.
I have tried to disassemble the ford oval but had no luck. What is the best way to take it apart?
Thread Starter #1,384
The Timberline version is the only one that comes apart. The normal blue ovals do not. For the TL over you just cut the ends off the melted plastic pins and it pops apart.
RusW1
Missouri
gorgeous car man! The new wheels are spot on. I just last nite did a middle of the night pain pill induced impulse buy of the 22x10.5 +30 set up that you perfected! Had a shoulder replaced a week ago and have since spent more than i care to admit to after reading your entire build. Thank you for sharing so much and being very receptive to answering all of our questions. Really appreciate it and you embody the forum sharing mindset. Kudos Unbroken.
Palm Beach, FL
Explorer ST 2022, Excursion 2000
What % are you using on the headlight outline tint/rear taillight blinker/reverse tint?
@UNBROKEN
Thread Starter #1,387
@UNBROKEN
The rear is the lightest tint Lamin-X has. The new heads I’m not sure what it is…the lightest PPF the shop had where I dropped them off.
NYC, NY, USA
It came out as well as I could have hoped. Pretty much spot on to my “render”. Still needs a lot of cleaning and paint correction on the rest of the car and I can’t wait to get the new wheels on. View attachment 28223
really love the hood vents, it came out perfect.
around how much did it cost to fabricate? im gonna start saving for this as my next mod
Thread Starter #1,389
I did all the fab work myself. I’ve heard others quoted north of $2K for fab and paint. The cut up Jeep hood and new vents ran about $200, supplies were another $300ish then whatever it cost to paint but I had other stuff painted at the same time so I’m not sure what the hood alone was.
Thread Starter #1,390
Back in town after an extended work trip. Picked up the newly upholstered shortened headrests to replace the others I had installed. These are the factory parts that I shortened 4” myself. They’re wider and match the lines of the seats better. IMG_7042.jpeg
Thread Starter #1,391
So a month or so ago I removed all of the audio in the back. Subs and amps were sold off and the new stuff has all been acquired.
I have a pair of Mosconi Pro 5/30’s that will be split with one running each side of the car and a Pro 1/10 that will run the Audiomobile Evo 2408 sub that’s getting built into the glovebox area in the next few weeks. The sealed enclosure was cut up and massaged to hold the pair of Acoustic Elegance IB15AU’s I had built for this upgrade. The floor was cut out and will be reinforced with a 3/4” thick 7075 aluminum stiffener ring combined with some aluminum mesh and hydrophobic foam to prevent water intrusion. I was making good progress today until the rain decided to blow in. I should have the manifold finished and installed tomorrow and hopefully adding electronics back in by tomorrow night. IMG_7125.jpeg IMG_7128.jpeg IMG_7056.jpeg IMG_7132.jpeg
Thread Starter #1,392
The 5/30’s will float over the 15’s something like this. The 1/10 will be hidden along with all the other electronics. The only thing I want to see is two subs and two amps…no wiring or anything else. IMG_7133.jpeg
Thread Starter #1,393
Sneak peek…ready to start wiring.
The finished vent through the spare tire well.
Omaha, NE, USA
Thread Starter #1,395
All wrapped up.
The 3rd amp is hidden and ready for the front sub that’s coming soon.
Looks great!
TheBurlyMan
Kansas
2024 Explorer Platinum
I'm working on making a template for the hood vent. Going to cut my hood this weekend.
Did you ever end up making the template for these vents? I bought the vents, but Im damn nervous to cut into this hood...
