COBB Accessport - Goosetuned Tuning thread
Supreme Ruler
EMT
Washington State
So, after watching, HSF, when do axels start breaking after HP increases? I love to go fast, and racing from the dig, but braking parts isn't something I want, but know that it happens. So, @ what HP does stock axels give up? Trans drums lose control? Motor internals need to be worried about?
This being a young plate form, I'm interested, Old Pontiac guy, made them go fast, but this SUV feels like it could do a lot, but it has some soft parts from the factory.
What say you?
20 Platinum
What say you?
Main thing you need to be worrying about is beefing up the rear end if you have a late 2021 - 2024 Explorer ST, single bolt's tend to break. Top off your transmission fluid if its below the line, always add 6.5 qts of oil during oil changes for those hard launches. Add steeda toe links and bushing subframe supports, IMO you should be golden under 600whp with everything else stock.
People have run 550-600~whp with the stock tranny no issues and every major component stock, internals have yet to be determined its max potential but there are 650+ whp ST's on stock internals,
Iowa
2022 Ford Explorer
What say you?
Lots of factors go into breaking axles.
#1 shock load. HSF uses his transbrake for launching.
#2 wheel hop/bunny hop. If you launch on a surface with too much grip or too little you will break stuff from a launch. If it feels like the cars shaking let out.
#3 suspension angle. Axle joints are strongest when they are level from diff to wheel bearing. Too high or too low turns the twisting torque from rotational to angular force.
The transmission internals start slipping after the 550ftlb range from what I've seen, though your tuner has more experience.
Major HP limiting congress from the factory fuel system. These turbo engines really like ethanol so you can keep the timing on them. Direct injection though is limiting somewhat there, there's only so many crank degrees allowed to fire the injector. This is why you will see lots of dynos on these ST with massive TQ numbers from 2,500 RPM and trail off like diesels. Guys have been piggy baking a 3rd party port injection kit though.
Internals are really stout as long as timing and knock are in control. Plenty of people 600+ at the tires, but after that it sounds like cap walking becomes a concern and limits longevity.
Supreme Ruler
EMT
Washington State
Trans brake, that's what I missed. That make complete sense, since he is using the T-brake. Thanks all.
GooseTuned
New Mexico
Thread Starter #265
What say you?
Yeah, I totally understand. I’m not one of those type of tuners going for all of the power, because it leads to exactly what you see.
I would say once you start launching the car very hard is when all of that stuff starts to happen. I have many customers already within the past year and a half that have over 50,000 miles and no issues.
It’s pretty easy to tell when you start asking for a lot out of these motors, as they will go from running well to grenade-ing immediately. A lot of that is due to excessive cylinder pressure on good fuel. Believe it or not you can overtime a Believe it or not you can overtime an engine. These are very strong engines, to break one of them will either take a lot of abuse, or irresponsible Tuning.
GooseTuned
New Mexico
Thread Starter #266
Luke set an official track record and official world record for the PIU platform!!
This was tuned on HPTuners (yes, we’re versatile!)
11.4@122mph! With a 1.77 60’
if we can get this on a real tire, and not 5yr old tires, he’s going 11.1s with that mph.
ctsweee
Colorado
Brand new user, first post, just ordered The goosetuned setup and I cant wait to check it out, I do have a question though, I did not order the Trans brake but might regret that, what is the main difference between your transbrake and the cobb "factory" one?
GooseTuned
New Mexico
Thread Starter #268
Thanks man!
I have mine setup to be more or less aggressive if you need it to be. I can explain more in our tuning email once we get started.
GooseTuned
New Mexico
Thread Starter #269
Anyone looking for tuning we are NOT applying the COBB Tariff surcharge!
Save even more by purchasing from us!
GooseTuned
New Mexico
Thread Starter #270
Looks like I didn’t update this!
He did end up going 11.1 a couple days later on the same tires.
Keep in mind this is STOCK intake, eBay intercooler, 5yr old tires, the most basic launch control available, and 134,000 miles on the car
All done in 3 months.
If any of you want PIU tuning let me know. We are currently over 1/2 second quicker than anything else out there.
THIS WAS DONE IN JUNE…summer. Not heeeer0 DA :geek:
20 Platinum
Those are amazing numbers! Good ish Goose!
So PIU tuning only thru HP Tuners and ST thru Cobb? Or do you also tune ST's thru HP Tuners now?
If i order the e50 tune from the goose website, will the Cobb access port come loaded with a 93 tune as well or would i need to select a secondary fuel?
GooseTuned
New Mexico
Thread Starter #273
This is HPTuners. COBB doesn’t support it, yet.
I’m only offering PIU on HPTuners
GooseTuned
New Mexico
Thread Starter #274
You would have to select both 93 + e50 as a secondary fuel
djk61301
la salle, il
21 ford explorer st
Is an ethanol sensor required for e50 tune?
GooseTuned
New Mexico
Thread Starter #276
Nope, just knowing the content that is in your tank either via hand calculating or pumping the exact content.
I recommend 38-40% for best power.
moto727
Jacksonville, Fl
What’s the tolerance range on an e50 tuned st for ethanol content?
GooseTuned
New Mexico
Thread Starter #279
I like no more than 40%. If you can do 35-40 like TNT said you'll be good
Arden Hills, MN, USA
Does the tune retain the pursuit mode that activates with aggressive driving holding the gears to keep the revs up. It is lots of fun when the blue horse light comes on the dash, the vehicle thinks it is party time.
