O2 Sensors?
I got a check engine light so I pulled the code and it read P0420/$07ES which is "Catalyst System Efficiency Below Threshold (Bank 1)". I have the SPD downpipes which are only two years old. Could this just be an O2 sensor? I figure I would get a code for it if it was. I ran a live view and the O2 sensors are showing the same value on both sides. Kinda scratching my head here. I can't imagine the cat would have gone bad in two years!
Do you have defoulers on?
No defoulers.
Following. I have over a year on my spd’s. No problems so far. How many miles? 50k or more you might have a lazy O2 sensor. Efficiency is usually post cat sensors. I will say dropping the spd’s should be way easier than the oem cats. You might even be able to get to the downstream sensors without dropping them. Could also swap left and right sensors to see if it follows the sensor. Not sure if there are unique left and right sensors.
I got a message in to SPD about it. I don’t understand why they have worked for two years and 20K miles without defoulers. Sensors have 51K on them so I’m going to change them and I’ll add the defoulers at the same time. Might as well.
Got lucky, some people have, you need the defoulers nonetheless.
Yep, exactly right! They emailed me back and said I was lucky I went almost two years. They are going to send me a set of defoulers for free. I think that’s pretty cool of them!
