O2 Sensors?
I got a check engine light so I pulled the code and it read P0420/$07ES which is "Catalyst System Efficiency Below Threshold (Bank 1)". I have the SPD downpipes which are only two years old. Could this just be an O2 sensor? I figure I would get a code for it if it was. I ran a live view and the O2 sensors are showing the same value on both sides. Kinda scratching my head here. I can't imagine the cat would have gone bad in two years!
Do you have defoulers on?
No defoulers.
Following. I have over a year on my spd’s. No problems so far. How many miles? 50k or more you might have a lazy O2 sensor. Efficiency is usually post cat sensors. I will say dropping the spd’s should be way easier than the oem cats. You might even be able to get to the downstream sensors without dropping them. Could also swap left and right sensors to see if it follows the sensor. Not sure if there are unique left and right sensors.
I got a message in to SPD about it. I don’t understand why they have worked for two years and 20K miles without defoulers. Sensors have 51K on them so I’m going to change them and I’ll add the defoulers at the same time. Might as well.
Got lucky, some people have, you need the defoulers nonetheless.
Yep, exactly right! They emailed me back and said I was lucky I went almost two years. They are going to send me a set of defoulers for free. I think that’s pretty cool of them!
I got the defoulers and installed them. Cleared the code and as soon as I started driving, the CEL came back on. Now I have a P0141 (Heater Circuit) code! Thought maybe it was just the connector so I tried pressing it together but that didn't work. When I tried to pull the connector apart it wouldn't budge! I can't get the damn thing apart! I took it to my mechanic and he tried and couldn't get it apart either. Unfortunately he was busy so he couldn't spend time messing with it. I've been laying on my back for about a half hour trying to get it apart but it just won't budge! At the moment I'm thinking about just getting a couple new sensors and then just cutting the stuck connector on the sensor side and prying it off. I just don't want to damage the vehicle side! Any ideas on how to get it apart?
As my luck goes, I got burnt by FordPartsDirect.com. Stay away from them! I ordered two new sensors and they sent me two used sensors! They didn’t even clean them! Both have heavy carbon build up! Glad I used PayPal! Just a freakin’ hassle!
Try Apple Ford Parts of White Bear Lake, I’ve always had very good luck with them and they tend to be cheaper than the other internet guys.
texas
Take a look at RockAuto. I got a new set of 4 motorcraft o2 sensors and it was less expensive than any Ford site.
That's strange! RockAuto was the first place I checked and they didn't show a listing for the Motorcraft sensors. Unless I missed it but I don't think so. All they had was the front right. They had Walker sensors for the rear but not Motorcraft. I just checked and they are coming up and are $56.79 each. That's less than what I paid FordPartsDirect for freakin' used sensors. I'm waiting to hear back from them to see how they are going to resolve it. If they give me a hard time I will just take it up with PayPal.
Man am I dumb sometimes! The sensors are not used! What I thought was carbon build up on the sensors and inside the bag is evidently a protective grease they put on them. Doooht! I contacted Tom’s Ford where they came from and he sent me photos of some other new sensors that looked exactly the same. Talk about feeling like an idiot! But, to my defense, I’ve never had them come like that before! It looks just like they are covered in carbon! Oh well, live and learn!
Funny. All the Nox sensors on my Ford trucks looked used like that and I thought the same thing. Then when I got the second and third is when I realized ford does this. All of my GM NOx and O2 sensors looked shiny and new.
texas
It looks like some sort of anti-sieze was put on the threads. The upper o2 sensors had a protective cap over the threads, so the inside of the bag was not a mess like the lower o2 sensors were.
Thread Starter #17
Well, as usual, the nightmare continues! Had a really hard time getting the passenger side connector apart. Finally got it and one of the pins from the male side came with the female side! The inside of the connector is all corroded! So now I have to track down a pigtail to fix it. I wonder if this would be covered under the ESP? I can’t catch a break!
Thread Starter #18
The cheapest I could find a new pigtail from Ford was $91 + shipping!! eBay has the exact same part, in the original packaging, for $35 and free shipping! I know parts are more expensive at the dealer but come on! The sensor was only $58! How can the connector cost more than the sensor?
Massachusetts
2023 ST
It's ridiculous isn't it? Anytime i've parted out a Ford, if I'm not selling the wiring harness complete, i clip all the connectors off. It's crazy what Ford sells them for.
Charlotte
Wow gross, that connector is all shitted up! I'd put some dielectric grease in the new to maybe prevent the stuck corrosion issue in the future.
