Widest front and rear rim and tires
Indianapolis
I am wondering what you guys think of the rear tires at 315/30r21 for the rear? I read an article about a track car (explorer st) that is set up for the track. Has roll cage and setup with 4 seats. They used a 315/30/21 for rear. Wondering if anyone has that size on their rear and if you can offer your expierence with them on the street. Also, wondering what widest set can go on the front without rubbing during turning. All this on H&R lowering springs. I am looking for a very aggressive stance. I like the low look with a little negative camber on wide wheels and large quad exhaust tips, 4" tips.
I ran 315’s square on 10.5” wheels.
You could run a 12” wheel out back if you did the math and got the offset right and fit a 325 back there pretty easily.
You ran 315/35r22 though without a problem right?
Yes. I wouldn’t recommend it if there was a fitment issue.
Some have ran an 11” wheel up front but they stick out too far for my liking so I wouldn’t recommend that. There’s just not enough strut clearance to work with. The rear is wide open for playing around.
What do you mean by fitment issue?
Tennessee
Currently running 22x10.5 square with 315/35-22 Conti DWS. Stock springs and no rubbing anywhere at all. She looks good with 4 fat tires on her.
Steeda springs on order, looks like everything should still clear when lowered about an inch.
CONNECTICUT
2020 EXPLORER ST
@UNBROKEN 315/35/22 are about .3 in bigger in diameter than the 305/35/22 - and obviously wider as well.. i want to run a 315/35/22 in the rear and 305/35/22 upfront - i went with the +30 offset - will the 315 fit?
CONNECTICUT
2020 EXPLORER ST
i have the H&R springs
If your car is AWD there’s too much difference in OD between those 2. It’ll freak out the computer. You can run 315 square though.
CONNECTICUT
2020 EXPLORER ST
Yep - AWD - 315 all the way around fits?that would look THICK!!!! lol - something to consider now! Thanks
2022 Ford Explorer Platinum
Yep. There are quite a few running them (thanks to @UNBROKEN who did all the math to verify it would all fit) I've loved the look on mine.
Tennessee
Oh yeah. Phat 315 Conti ExtremeContact DWS06 Plus on 22's square.
Charlotte
2021 Ford Explorer ST
What offset were you running though? I found a pair of 20x10.5s I’m debating running with some 285/50r20s that have a +45 offset. Wanting to know if those will fit in the front and not come in contact with anything. If that won’t work I’ll just be going with a set of 20x9.5 +33.
(Also curious why you used past-tense, why get rid of the wheels you had? Or did you just get rid of your car.) (I previously had a set of 20x10s +25 with 295/45r20s and had to remove them because it made the steering WAY too heavy/difficult to what I can only imagine was because the offset was too low, even though they were perfectly flush with the fenders.) (I read somewhere that not increasing width on inside of wheel/tire and only increasing outside can cause that issue if you don’t have adjustable control arms and aren’t able to reset the kingpin inclination angle.)
No you cannot run a 10.5 wide wheel at +45. +30 is the proper offset for that width.
Bridgewater, New Jersey
Any of you guys with wide tires, can u post some pics of the look n size u went with?? @UNBROKEN ,to go wider would I need to ditch the stock rims ??
I also have spacers on , 3/4" front and 1 1/4" on the back ..would i get rid of them or leave on? I dontbwant the tires sticking out of the fenders if possible..thankx
Assuming stock 21’s you’re maxed out at a 295/40. Those would be really flush with 1” spacers and rear camber at -.5°.
OK , yea I still have the stock rims and tires. I just put the spacers on to get flush but want to go alittle wider with the tire..
bigspoon86
arizona
2020 explorer st
what is your recommendations for the 20s as far as the widest setup to run stock rims still. Seems like you have a bunch of knowledge on tire setup,TIA
