Wheel model and tire size? I've been looking at Bronze 20x10 for my dark gray, with fat Extreme Contact tires.
Edit, I see your sig. Which wheel model? Basically, what I want lol.
They are Velgen VF5’s in gunmetal gray.
How does it look from the rear? Interested to see your over-the-top stripes and how that exhaust looks. Very clean/nice looking vehicle, especially the wheels!!
Not the best pic but gives you the idea. We had some light snow last night. I’ll get a better shot once it warms up and melts.
I think i like that!
Yeah, me too! They are just vinyl for now but I want to have them painted on. The paint around them is going to fade and it will look silly if, or when, the vinyl comes off. There’s already a few spots. The vinyl doesn’t like it if you don’t rinse off the soap right away when washing the car.
MO
2026 ST AWD
Diggin' those stripes on the Silver Spruce Metallic, BruceDaMoose - very nice. Sweet looking wheels, too, and a nice stance. You are a man of impeccable taste.
BDM, not sure about those muffler tips sticking that far out! ...To each his own I guess.
D
Deleted member 23258
Guest
Detail baby, it’s all about the detail!
Your Explorer looks great. I love the color and those rims set it off perfectly!
D
Guest
I have not the opportunity to post our 2026 Space White Explorer ST. The outside is strictly stock. I have competed some installations under the hood, though. This is how it went; it's a long read.
After reviewing a few sites, information presented in the forum, and from my own experience with my Dodge Challenger 392, I knew a catch can and an air inlet tube would be good ideas. I decided to use the UPR Plug N Play™ Dual Valve Oil Catch Can with ECSS, the FenFab 2020+ Ford Explorer ST cold air inlet tube, and the FenFab 2020+ Ford Explorer ST ECM Cover and backing plate.
First, the catch can, IMHO, is not truly plug-n-play. Those orange one-time quick connects are a pain. I used the alternate method described in the UPR instructions where they say to remove the outer black part of the quick-connect, then remove the orange part. Once that was done, then I had to go to Lowe’s and get a heat gun to heat the air tube ends to remove those orange quick-connects and insert the UPR supplied quick connects. My wife’s hairdryer wasn’t hot enough. That part wasn’t too bad. The next thing with the UPR catch can was that they shortened the hoses from the ones I’ve seen on several videos for the 2020+ Explorers. When the tube on the driver side was installed with the new UPR supplied quick-connects, it wouldn’t fit as it did from the factory, because the T-fitting down by the turbo was too tall to allow reinstallation as it was from the factory. I had to run that tube outside between the engine and the left strut tower. I noticed in a UPR installation video, they did the same thing with their Explorer in the UPR shop. It would’ve been nice if UPR had explained this. The UPR supplied quick connects seem to be made of a softer plastic than the OE Ford quick connects. I’m wondering how well the UPR supplied quick connects will hold up long-term. Lastly, after I had attached the catch can to the radiator support on the driver’s side, I wasn’t able to get the screws tight enough to keep the catch from twisting around. I went through my load of spare fasteners and found two stainless steel fine thread screws with hex heads with a lock washer and flat washer. I went to Lowe’s and got some extra ¼” stainless steel lock washers to use on the screw where the catch can attaches to the underside of the radiator support and for the other end as well. It was more secure once these were tightened up.
As for the FenFab items, they seemed to be well made. However, the air tube was a about 1/8” to ¼” of an inch too long at the throttle body end. There were no instructions. It’s obvious it wouldn’t fit but one way, but someone who is less mechanically inclined might have a less than easier experience. It was the same with the ECM cover and backing plate. On my 2026 Explorer ST, where the air tube attaches at the radiator support, it has white grease all the way around the inlet. You’ll need to clean this area very well before you attach the supplied adapter. If not, when you tighten the clamp, it’ll slide off.
I’m happy, overall, with the results. I’m not making any attempt to bash UPR or FenFab, but I wanted to describe my entire experience with these items for those who are new to these installations and who might not have much auto mechanical experience. There’s nothing worse than a rude surprise when you get in the middle of an installation that you’ve been looking forward to completing, and then you find that it’s not going to go as smoothly as it seemed in the instructions or certain manufacturer videos. Thanks for looking and reading. Side view.jpg
I’m having them straightened out. I know they look stupid right now. One sticks out further than the other and they both stick out way too far! The pipes needs to be cut back and I don’t trust myself to get them even.
Your Explorer looks great. I love the color and those rims it off perfectly!
I’m very happy I went with this color! Got to give props to @UNBROKEN for suggesting it! I almost went with the bronze but I’m glad I didn’t.
After reviewing a few sites, information presented in the forum, and from my own experience with my Dodge Challenger 392, I knew a catch can and an air inlet tube would be good ideas. I decided to use the UPR Plug N Play Dual Valve Oil Catch Can with ECSS, the FenFab 2020+ Ford Explorer ST cold air inlet tube, and the FenFab 2020+ Ford Explorer ST ECM Cover and backing plate.
I’m happy, overall, with the results. I’m not making any attempt to bash UPR or FenFab, but I wanted to describe my entire experience with these items for those who are new to these installations and who might not have much auto mechanical experience. There’s nothing worse than a rude surprise when you get in the middle of an installation that you’ve been looking forward to completing, and then you find that it’s not going to go as smoothly as it seemed in the instructions or certain manufacturer videos. Thanks for looking and reading. View attachment 34439
Not sure if they changed something or the 25+ are different, but my catch can went on pretty easily. The only issue I had, and it wasn’t really an issue, was getting the connector at the valve cover off. I just broke mine and it came right off. The can does move around with just the supplied hardware though. I also used ss but with a nylon lock nut. Still swivels a little bit if you put some effort into it but it’s ok because I know the nut is not coming loose.
D
Guest
I asked UPR and FenFab did they know of any specific changes in the 2026s and they said they weren’t aware of any. One other thing I noticed was the hole used to mount the cc in my instructions was different than many of the photos and videos I reviewed. In those, facing the front of the Explorer, the cc was mounted in the hole to the left of the hood bumper. In the instructions I was sent, they mount it in the hole to the right, nearer to the headlamp.
Winnipeg
Explorer st 2025
Painted the big silver back boxes black, a bit easier on the eye now. Exhaust tips next job. Screenshot_20260316_132541_Gallery.jpg Screenshot_20260316_132601_Gallery.jpg
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
@Nianiamh :
You are a better painter than me!!!
When you get a chance, jump over to the "Exhaust Tip Questions" thread where you will see @drcookie , @Leadfoot and I have been discussing exhaust tips on the ST's. I loved the looks of @drcookie's application of WESDON Stainless Steel Tips so I got some for me. At this point I am not 100% sure which complete exhaust system upgrade I will end up getting (know a lot about BORLA from previous 2 Mustangs but also love the Thermal R&D 2.5"s) in the future.
My main issue is the "Fake Engine Noise" that is pumped into our interiors. I do not want to install a really nice system until one of our more learned members here figures it out or FORD brakes down and tells us how to PERMANENTLY disable that silly nuisance WITHOUT causing collateral damage/problems to other systems in the vehicle.
Until then, I have the look I wanted.
Finished view:
During conversion process: stock left side tips there really look cheap compared to new Wesdons on the right.
Winnipeg
Explorer st 2025
@Nianiamh :
Finished view:
Trust me if you stand across the street while I pass at 70mph my paintwork looks perfect lol.
I've gone for some of the stainless/fake carbon look tips 3.5 inch, hopefully get em fitted soon when it warms up a bit here.
D
Guest
@Nianiamh :
Finished view:
They look great!! Would you post the part number? On the Wesdon website, application is by size. Thanks!
D
Guest
I ended up using stainless steel lock and flat nuts and two stainless steel hex nuts They worked and it's tight!
Nascarbilly
Sacramento, CA
@DSGR :
Many thx for your comment; they give me "that look" I was going for
As for part numbers, I used AMAZON, @drcookie could get you his order info since he did NOT use AMAZON.
https://www.amazon.com/dp/B08CTPZCFY?ref=ppx_yo2ov_dt_b_fed_asin_title
Exhaust Tip 2.25" Inlet 4.00" Outlet 8.00" long Slant Angle Stainless Steel Wesdon Exhaust Tip
$44.99 EA
About this item
  • Exhaust Tip 2.25" Inlet 4.00" Outlet 8.00" long
  • Fits a 2.25 Inch Exhaust Pipe Weld On
  • Slant Angle
  • Polished
  • 304 Stainless Steel (Please measure to make sure it fits your Car or Truck) 2.25 Inlet
  • This is made to fit a 2.25” exhaust pipe. Please measure your exhaust pipe to make sure you have a 2.25” exhaust pipe outlet and that you have the room for it to fit.
Install hints:
a) The exit pipes from the stock mufflers are almost tooooo close together for these exhaust tips to fit properly without touching/rubbing (possible vibrations). I took the pics @drcookie shared with me to the muffler shop and the Technician slightly elongated the inlet portion of each exhaust tip. This gave the installed pipes about 1/8" to 3/16" gap between the pipes.
b) Per Technician, do NOT let anyone talk you into clamping them on as spot welds prevent some enterprising thief from "borrowing them" from you. LOL, LOL!!
Nascarbilly
Sacramento, CA
View attachment 34490 View attachment 34491
@Nainiamh : I think your selection will work perfect as it will compliment the exterior of your ST. Great choice!!
California Bay Area
@DSGR :
$44.99 EA
About this item
  • Slant Angle
  • Polished
Install hints:
You could purchase from the same vendor from Ebay where I bough them. :)
The setup from @Nascarbilly looks better as the gap between two exhaust tips on muy setup are super small. They are too close which makes the cleaning a little challenging. :D:D:D
