Well, Well, Well ....
Autoworker
We started to get water that was discolored coming into the house. After eliminating it wasn't the softner, we made a call to a well driller. 23 yr old well, 55 feet deep, never been opened since drilled. Determined it was magineese, decided to blow out the well. Pulled the pump, and ran an air line down to the bottom. 350 psi of air made a boatload of crap come out! Magineese, sulfur, and iron build up. Cleared up after about a half hour. Plenty of water, 20 gallons / minute. Literally had to hammer the magineese off of the pump. Everythings back together, ran another hours worth of water before putting the house online. (y)
Sulfur
Magineese and gravel
A quarter inch of scale he hammered off of the pump.
Chaseg08
Golden, CO, USA
20 gallons a minute! That's awesome. I have a 150 ft well and I'm at about 2 gallons a minute, which is great up here in Coal Creek Canyon, CO. We're at 8900 ft and our water is redish yellow through spring into the summer because of all the iron. We live on pretty much solid rock. Mostly granite. I have neighbors that have to have water delivered and can't do laundry towards the end of summer through fall.
EDIT: We have a 1500 gallon cistern and about 75 ft of water in the well. Once it's drained, it's refresh rate is about 2 gallons a minute.
Autoworker
Autoworker
Is you water table low due to lack of rainfall? Good that you have a cistern.
Chaseg08
Golden, CO, USA
It's a combination; Colorado is a high desert and very dry plus my mountain is solid granite. My neighbor about a quarter mile away had to pay 20k to frack his well and he still has problems.
CareerFiremanGuy
Sulfur
"Honey, the lemonade tastes funny?"
"You're imagining things. It's fine."
