Upgrade front brake system from 345 to 363 with Ford parts.
Klisewski
Virginia
2020 Lincoln aviator
I accidentally brought the wrong size rotor and I decided I'm going to try to upgrade my 345mm brakes to the 363mm high series on my Lincoln Aviator 2020. I look through the Ford catalog and found the high series caliper slide bracket and brake lines. These parts don't show up when I use my VIN but they are installed on other aviators. Has anyone upgraded their brakes with Ford parts like this? Will it fit?
(I am aware I'm on the ST forum but it's my understanding they are virtually identical vehicles. The high series brake caliper would be equivalent to the red caliper on the ST if I'm not mistaken)
If you want to upgrade from your base brakes to the bigger ones, you need the calipers, rotors, mounting brackets and that’s it.
K
Klisewski
Virginia
Ok thanks, I was just thinking that maybe the caliper wouldn't be compatible
Yeah it isn’t, you need the bigger calipers with their mounting brackets.
K
Klisewski
Virginia
By bracket you're referring to this correct or are you referring to a bracket between the caliper and the knuckle.
Yep that’s what I’m talking about.
jmitchelltfo
Fort Leonard Wood
2022 Aviator, 2021 F150 Powerboost
Any follow up to this upgrade? I will be shopping for rotors and pads for my wife's Aviator and I would like to see about the 363mm upgrade vs the GT350.
She doesn't "need" the bling of the GT350........but if parts are in the same ballpark for the price, I would definitely consider them.
It’s hard to say what Street Pack brakes upgrade will cost because it depends on how much you purchase used ones for.
Nebraska
The brake shields are also different, but have read the ones for the smaller brakes can be modified to fit. They are not simple to swap from what I've read.
jmitchelltfo
Fort Leonard Wood
I only need the front since the Aviator has the same rear setup as the PIU/Street Pack, so it shouldn't cost that much. I've found a seller with low mileage calipers for $200 (both sides). I'd only need to find the backing plates, mounting brackets, pads and rotors after that. Looks like I could get everything put together for $600-700 depending on my choice in pads/rotors which will probably just be OEM unless there is another highly recommended option for a daily driver.
That’s about a grand cheaper than the GT350 setup. OEM is just find for rotors and pads, I like the Powerstop units because they look neat, but they don’t help braking performance.
