Updated FORScan sheet for 2020-24 Ford Explorer (All Trims)
#81
What I am really interested in is changing the heated steering wheel temperature. My wheel seems to barely get warm and I want to see what the settings are of it in forscan. However, I was unable to locate it within forscan. Would you have any insight on where these settings are?
That might be a mechanical issue, and not necessarily a ForScan setting that needs to be adjusted. I would imagine if there are settings for it, they would be in the HVAC module as that's where the heated seat temps are.
My steering wheel gets plenty hot within a min or two and I end up turning it off. What I need to do before winter is play with the heated seat temps. The hottest setting is a bit too hot. So i'd like to drop that down a tad, and bump the middle setting temp up a little too.
Chicago, IL
Unfortunately in my HVAC module, the only settings I have are to disable/enable to HSW. There is the actual coding HVAC module but I have no idea what the code means.
#83
This is on my to-do list so let me poke around and see what I can find. Chilly AM today and it annoys me that the highest seat heater temp is uncomfortably hot.
EDIT: I see the same. Pulling a few as_builts from the Ford website using Explorer VIN's i've found for sale, i don't think temp control is enabled on the wheel. I could be wrong.
I do see it for the seats. 55C(131F) , 46C (114F) and 35C(95F) seem to be the defaults. I changed mine to 52, 48 and 35. Lets see how that works.
Chicago, IL
Really unfortunate! I'm not sure if the HSW is just not good by default or if it's defective.
Charlotte
2021 Ford Explorer ST
#86
Below is the link to the updated FORScan changes that is currently available for our 2020+ Ford Explorer and applies to all trims for those who don't have an ST. This one is for us, which helps compile all into one.
LINK: https://docs.google.com/spreadsheet...ukfkgBqYkDE2w8imywaNF8VJF8/edit#gid=671029316
Can we get codes for the ability to disable PDC (pull drift compensation) and adjust EPAS (electric power assisted steering). I’d really love to change the steering settings to comfort so I can maneuver this thing easier and not always need 2 hands on the wheel to turn this thing. That’d be great. Also, does Forscan have to be a specific version to use?
King george VA
2022 st
#87
Is there a comprehensive list of these mods in the easy mode. All the numbers scare me. Lol
