Updated FORScan sheet for 2020-24 Ford Explorer (All Trims)
#81
What I am really interested in is changing the heated steering wheel temperature. My wheel seems to barely get warm and I want to see what the settings are of it in forscan. However, I was unable to locate it within forscan. Would you have any insight on where these settings are?
That might be a mechanical issue, and not necessarily a ForScan setting that needs to be adjusted. I would imagine if there are settings for it, they would be in the HVAC module as that's where the heated seat temps are.
My steering wheel gets plenty hot within a min or two and I end up turning it off. What I need to do before winter is play with the heated seat temps. The hottest setting is a bit too hot. So i'd like to drop that down a tad, and bump the middle setting temp up a little too.
Chicago, IL
Unfortunately in my HVAC module, the only settings I have are to disable/enable to HSW. There is the actual coding HVAC module but I have no idea what the code means.
#83
This is on my to-do list so let me poke around and see what I can find. Chilly AM today and it annoys me that the highest seat heater temp is uncomfortably hot.
EDIT: I see the same. Pulling a few as_builts from the Ford website using Explorer VIN's i've found for sale, i don't think temp control is enabled on the wheel. I could be wrong.
I do see it for the seats. 55C(131F) , 46C (114F) and 35C(95F) seem to be the defaults. I changed mine to 52, 48 and 35. Lets see how that works.
Chicago, IL
Really unfortunate! I'm not sure if the HSW is just not good by default or if it's defective.
Charlotte
2021 Ford Explorer ST
#86
Below is the link to the updated FORScan changes that is currently available for our 2020+ Ford Explorer and applies to all trims for those who don't have an ST. This one is for us, which helps compile all into one.
LINK: https://docs.google.com/spreadsheet...ukfkgBqYkDE2w8imywaNF8VJF8/edit#gid=671029316
Can we get codes for the ability to disable PDC (pull drift compensation) and adjust EPAS (electric power assisted steering). I’d really love to change the steering settings to comfort so I can maneuver this thing easier and not always need 2 hands on the wheel to turn this thing. That’d be great. Also, does Forscan have to be a specific version to use?
King george VA
2022 st
#87
Is there a comprehensive list of these mods in the easy mode. All the numbers scare me. Lol
EDWYER
#88
Subbed.
locoliberty
michigan
2022 ST
#89
Does anyone have insight into the ABS brakes settings? there is a calibration for "police", any real answer on the difference between that and the ST cal?
KEKS
Schweiz
Ford Explorer 2022 ST
#90
Hey zusammen
Ich habe einen Ford Explorer 2022 gekauft, bei dem bereits einige Systemänderungen vorgenommen wurden. Nun möchte ich fragen, ob jemand die Sicherungskopie der Einstellungen eines Ford Explorer 2022 besitzt oder wo man diese herunterladen kann, um das Fahrzeug wieder auf die ursprünglichen Einstellungen zu setzen, damit ich von Grund auf neu starten kann . Weiter die Frage, gibt es eine Schritt für Schritt Anleitung, wie ich das Backup wieder auf den Explorer spielen kann?
Keks
Hey everyone,
I bought a 2022 Ford Explorer that already has some system modifications. Now I’d like to ask whether anyone has a backup copy of the settings for a 2022 Ford Explorer, or knows where it can be downloaded, so I can restore the vehicle to its original settings and start from scratch.
Another question: is there a step-by-step guide on how to load the backup back onto the Explorer?
Keks
Jd24858
anyone know what values in the AWD module to change once you remove the FADA with the ball bearing carrier shaft? FDRS is giving me trouble, I have the mongoose obdII cable and 14 volt power supply. Just not sure if the module is bad. I did rewire the grounding circuit to a bare metal stud.
#93
You just update the AWD module in FDRS. It will ask you if you have an electrical harness connected to the FADA. if you replaced it with an intermediate shaft, you just say no.
Jd24858
I have been doing that. Fails every time. Trying to update other modules and it fails too
Jd24858
Turns out FDRS was corrupt. Redownloaded and it’s working.
Kkhoshaba
Removes "Full View Not Available" message in rear camera view.
(Allows cams in motion at any speed without black box in middle)
APIM 7D0-02-02 xxx*xxxxxx--If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7
Note: reset APIM after the change
Does this work on 2020 explorer too? I know it’s for the 2025+
Gadgtfreek
#97
Thanks for all the data posted here.
AvadaK
Charlotte
2020 Explorer Platinum
Hey, I believe I found the values needed to enable glare-free on the 2020-2024 Explorer Platinum. I compared a Canadian Platinum as-built against a US Platinum and the changes are in the APIM, IPMA, IPC, and SCCM modules, not the HCM. I already reached out to @Nightshade about this as well. My car is currently in the shop and I still need to get a Windows laptop and OBDLink EX adapter, so it’ll be a little while before I can test (maybe this weekend, if not next week). Happy to share the full values if anyone with a Platinum wants to take a stab at it before I get to it!
