Throttle body upgrade?
Odessa, Texas
Hello everyone. I was browsing parts on lethal performance and saw that AFE is offering a 65mm throttle body upgrade that fits the explorer ST. I am curious if anyone has done this upgrade and if it was worth it at all? I understand it would be most beneficial with upgraded turbos or bigger/serious builds.
Link? Never heard of it nor anyone running any aftermarket unit.
Not really needed on a pressurized system like this. No on something that draws through like a Whipple supercharger you want as big as you can get. IIRC the one on my F150 was 132mm.
X
Odessa, Texas
X
Odessa, Texas
I'm just curious how much of a difference it makes. Regardless on amount, considering its less than $500. I know there's people that will buy anything that helps give them any kind of power.
Massachusetts
2023 ST
I'm curious if it needs tuning. I have no plans to install one however.
I know when i change throttle body size on my Mustangs (N/A setup if that matters), i need to make some slight adjustments to the tune for drivability.
None. I tested a bunch of different size TB’s on a ProCharged truck of mine…none made any more power but the bigger they got the more drivability issues showed up.
If you got a aftermarket throttle body you absolutely should tune for it.
The up to +8 is the gotcha. It might be 8 but it might be 0. I seriously doubt you'll get anything out of it without mods to support it.
X
Odessa, Texas
I currently have down pipes, full exhaust, and intercooler. This weekend i will also be installing all of the fenfab intake and charge pipes, as well as a zfg tune after all is installed.
They’re the same ones who claim huge gains with drop in filters and intakes, I don’t ever trust these type companies numbers.
Read post #7 again.
