Single Differential Bolt
561
the
Steeda differential brace is highly effective at strengthening the 2020+ Ford Explorer differential, reducing movement, and preventing damage from broken bolts during hard acceleration. It increases rigidity, improves shifting, and reduces rear-end wheel hop, making it a key upgrade for performance and reliability.
1773796531669.png Steeda +4
  • Key Benefits: It distributes loads across the rear diff case, minimizing lateral movement and preventing failure.
  • Performance Impact: It provides a more connected "direct" feel and smoother shifts by keeping the differential in place.
  • Compatibility: Designed for 2020-2026 Explorer models (except 2.3L XLT AWD), including the ST.
  • Installation: Generally straightforward with basic hand tools, though it does not add to NVH (Noise, Vibration, Harshness
Are you trying to convince yourself? I don’t need a commercial and neither do most others here.
