Single Differential Bolt
561
Found doing an AI Google search:
Steeda differential brace is highly effective at strengthening the 2020+ Ford Explorer differential, reducing movement, and preventing damage from broken bolts during hard acceleration. It increases rigidity, improves shifting, and reduces rear-end wheel hop, making it a key upgrade for performance and reliability.
Steeda +4
  • Key Benefits: It distributes loads across the rear diff case, minimizing lateral movement and preventing failure.
  • Performance Impact: It provides a more connected "direct" feel and smoother shifts by keeping the differential in place.
  • Compatibility: Designed for 2020-2026 Explorer models (except 2.3L XLT AWD), including the ST.
  • Installation: Generally straightforward with basic hand tools, though it does not add to NVH (Noise, Vibration, Harshness
Are you trying to convince yourself? I don’t need a commercial and neither do most others here.
DSGR
DSGR
Wilmington, North Carolina
Thread Starter #23
No Sir and I didn’t expect any - for the record I tried to cheap out and bought the AWR brace first. It’s impossible to get the top right bolt back in without cutting 1/2 inch off the bolt (didn’t want to do that) unless you have midget hands with mosquito leg fingers, plus it only protects the right side leaving the left side to twist and torque to its heart content. In short its a POS sent it back.
Yep, I looked at a lot of the info about the AWR and I wasn't sold on it...like you said, it mostly protected the right side. Defeats the purpose!
It’s not that it only affects one side, it’s how it does it. When you have the flexible oem bushing on one side and hard poly on the other it causes a weird twisting of the diff on hard launches. There’s videos floating around showing that. When CPE engineered the ID Speed brace they spent months running calculations and testing to get just the right bushing to prevent that from happening and make the diff act like a factory 4 bolt car. Having a brace only on one side is fine…as long as it’s the right brace.
