Self powered sub
Vince4188
Montreal
2021 explorer ST
How can I connect a self powered sub that only has low input rca connectors?
LOC (line output converter) will take speaker level output ant turn it into pre-amp inputs. Not the best solution for sound but works fine.
V
Vince4188
Montreal
2021 explorer ST
Is the car amplifier located in the rear right side of the trunk?
Do you know if that amplifier would have low output jacks that i could use?
San Francisco
2022 ST
There is a writeup here where someone installed a sub and tapped the line inputs before the factory amplifier - I would look there
Left rear attached to the sub enclosure with the B&O and no outputs. You’ll have to tap in high level with a LOC.
San Francisco
2022 ST
^ Well, I thought there were line levels to tap, but UNBROKEN sure is the person to ask, so I certainly remembered incorrectly.
(y)
