R&D Ford Explorer Makes 570+ RWHP on the Dyno | ZFG Racing
Marinette, WI, USA
Hey guys,
I realized I never got around to sharing the baseline dyno numbers for my R&D Explorer, so I wanted to get this video out there for you all.
I only have easy access to a 2WD dyno down the road from my house, which definitely makes dynoing an Explorer a bit of a challenge. You can pull the plug on the transfer case to run it in 2WD (which is what I did), though there's still a bit of drag on the system because it’s a clutch-type transfer case.
The Setup & Numbers:
For this run, the setup was:
  • Fuel System: Nostrum High-Pressure Fuel System on E85
  • Intake: Houston Speed Freaks
  • Intercooler: Upgraded (installed while rebuilding the front end after a deer incident!)
  • Exhaust: Thermal R&D
We put down 577 RWHP and 576 WTQ! This is up from the 535 HP we saw on Nostrum's AWD dyno when it was just the fuel system and tune on a bone-stock vehicle.
Between the upgraded intercooler and the Houston Speed Freaks intake, we picked up about 40 HP. I ran an inlet pressure sensor on the stock airbox and saw a 2.5 PSI pressure drop, whereas the HSF intake has virtually zero restriction (less than 0.1 PSI drop), which really highlights how restrictive the factory box becomes when you start pushing things.
What's Next:
Since this dyno run was completed, the Explorer has already been under the knife. The stock engine and trans are out, and we've swapped in a built motor (10.5:1 compression) along with a built 10R80 transmission from RSA.
We are currently testing some highly anticipated prototype turbos. I'm knee-deep in the R&D process with them right now (working through compressor cover adjustments, wastegate mods, etc.) so they are perfect before release. I'll be sharing the engine/trans swap video and turbo data as soon as we finish dialing them in!
Check out the dyno pulls and the full breakdown here:
Let me know what you guys think!
Outstanding! Out of a 3L V6!
Gadgtfreek
The thing is wild on 93 pump gas and a tune. I can't imagine...
Hey guys,
What's Next:
Great numbers, excited to see this build progress.
Catmonkey
Louisiana
When you consider these engines are only 180 cubic inches, that's pretty incredible. These pulls were with the OEM downpipe/cats?
ZFGracing
Marinette, WI, USA
@ZFGracing can your tunes be installed via cellphone or tablet? Or is a windows laptop mandatory?
I would say more than 90% of my customers are using the app only now. It's really gotten a lot better especially with the 2025 plus and the fast Flash etc.
Sent from my SM-S948U1 using Tapatalk
