PIU rear sway bar
WA
Tried search, didn't come up with much.
Would upgrading to PIU rear sway bar be a worthwhile upgrade? It's about half the price of Steeda/AFE. Direct swap with ST hardware?
Thanks.
Can't answer the question but one thing to consider is that the PIU one is not adjustable.
The midwest
The PIU rear bar is in between the ST and Steeda/AFE bars, so of course it’s an upgrade. There are a few threads with comments on the PIU parts already. The PIU rear shocks are also allegedly stiffer, which could be a great combo to cut down the understeer. I have these parts waiting to go on mine since I’ll be removing the rusted Steeda bar. All said and done, the PIU bar & shocks together all came in around $350, FYI. Not a bad deal at all.
R
WA
Good point. Although I would probably just use the middle setting.
R
WA
Yeah, solid deal. Are you leaving the front struts stock?
The midwest
Yes. I want only the rear to be stiffer since that’s the way to trim down some under-steer.
True, but a thicker bar is still going to tighten up the rear over a stock bar, just not to the extent of an adjustable bar. The difference may be minimal anyway, but I’ll know soon enough when I make the swap.
New Jersey
Has anyone tried the PIU bar yet? A good amount cheaper, no worries of paint flaking in salt areas, and no potential squeaking / fitment issues. Seems like a win?
also can someone confirm the part number for it? Is it LB5Z-5A772-C?
The midwest
Have had the PIU rear bar and matching shocks on for a couple months now. Nice improvement and even better that it isn’t going to rust out like the Steeda bar. You have the correct p/n.
Thank you. Ordered, 138 to my door
Jessup, MD, USA
Do you happen to have a visual comparison between the OEM and the PIU swaybars? I'm assuming the PIU is thicker?
@jwuonog It doesn't look much different but it def weighs more. here is my video.
The midwest
I’ve mentioned the sizes in other threads. Off the top of my head, the OE bar is around 21.5mm and the PIU is 23mm. Not a ton larger, but still an improvement in stiffness. All the bars have tags on them in the middle that shows the diameter.
Jessup, MD, USA
Since you've had the Steeda and the PIU bars, do you notice a major difference in performance? What setting did you use on the Steeda?
The midwest
Used the tightest on the Steeda. The PIU bar is a close second and still better than stock when using the matching shocks.
Pittsburgh
2025 Ford Explorer platinum
I just got mine 2025 and I’m going to do the same thing tired of the understeer but should I just get the sway bar and leave everything else stock will that help? Cause I don’t feel like getting the other one I know it’s a little bit better but I live in Pittsburgh. It’ll be rusted out within six months.
Just getting the PIU rear bar will still help.
Pittsburgh
Do you have a link or a website to go to or where can I get it?
Save your money and wait until you can get an AFE, Steeda or the likes. Down the road you'll be glad you did, not to mention you can get more out of these than a 1 position Interceptor bar. What's the extra $150 over a couple of years.
#20
Agree, I paid $279 shipped for my AFE. The red looks nice as well.
