P0299 - Super odd - Tune glitch?
Minnesota
2026 ST
Was on a 650 mile roadtrip yesterday, at ~550 miles, was cruising at 60 mph and barely tipped into it, P0299 Turbo Underboost Condition popped up and went into limp mode. I thought I popped a charge tube somewhere (which happened immediately after the CVF intercooler and charge pipes were installed, easy fix).
Pulled over, checked every coupler, all tight . . . Cleared the code with the RTD4 and all good, Got into it hard a few times after and making 22.7 psi no problems. Put another 150 miles on since then and all good. Weird, right?
Has anyone ever seen anything like this? I'm not sure if could be an unexpected condition in the ECU tables or possibly a sensor?
ADHeimke
PHX, AZ
2026 ST
I had the same thing happen this weekend. (‘26, CVF, ZFG, 7k miles on car). Same, happened at very light throttle, also gave the “service engine soon” message. I had to drive a few miles before I could stop, but I initially didn’t really notice loss of power, it was all very light throttle, heavy traffic… went to pass, that’s when I realized I had no ponies…. Stop, shut off engine, check hoses, etc., found nothing, puled the code, reset the code, restarted, “wrench” light gone, power normal, so far 500+ miles later, multiple restarts, some WOT moments, it’s running perfectly.
i am guessing (only guessing at this point) that it had a momentary error in a sensor output which kicked it into some kind of limp mode that required either engine restart or having the code cleared. Once restarted and/or cleared, all fine.
Monitoring, researching. Thoughts? Comments?
Beerman
Minnesota
2026 ST
This gives me some comfort to know I'm not the only one. And yeah, when I say "limp mode" same as you, just had no power, felt like I was running on 150hp, so totally driveable, just not good for passing or anything similar.
I was on ZFG Race 93 when this happened and it's been perfect (and a lot of fun) for 3000 miles before this happened. Hopefully this isn't something that happens often. But I'd love to hear if anyone here has more insights into why and if there's anything that needs to be or can be addressed.
ADHeimke
PHX, AZ
2026 ST
ZFG Performance 91 for me, best fuel we hav around here.
Super Happy with ZFG. I expect that if it IS a problem with the tune, they’ll help sort it. If it happens again, I will reach out to them.
I’ve had two random overboost errors in two years of running a ZFG tune on my ‘22. Happened about a year apart.
Last time I flashed to update the sport mode shifting, it wiped my oil change interval. Never seen that one before. Other than that, it's been smooth since October last year.
