October Software Update Installed Today
New Albany, In.
2025, Explorer ST
Haven't figured out how yet
And if you have an auto start/stop eliminator, you once again have to unhook the negative battery terminal for a little while and hook it back up for it to work properly. WTH is it with these updates that disables the auto start/stop eliminator.. . After this October update, my start/stop eliminator stopped working again like has happened with a few other updates. I unhooked the negative earlier today and waited a while and hooked it back up. I'll be driving it in about an hour so hopefully it works right again.
Since the software update, I have lost the ability to do a soft reset by holding the power button down for ten seconds. Does anyone know how to do a soft reset?
Try pressing the power button and fast forward at the same time until it resets.
New Albany, In.
2025, Explorer ST
mine is working after the update.
Gadgtfreek
Mobile, Alabama
2025 Explorer ST 4WD
Thread Starter #26
My auto start stop hasn't had a problem yet, even after the update.
So strange.. Mine has been affected 3 or 4 times right after updates happen.
New Albany, In.
2025, Explorer ST
#29
This is from the owners manual.
that is for a reset/wipe of any info on the system. There used to be a reboot function, some people call it a soft reset but that's not really what it is, holding down the power button for 10 seconds would reboot the system (infotainment) which would help resolve a lot of glitches in the system.
With this new update, this reboot function is not working anymore.
Gadgtfreek
Mobile, Alabama
Thread Starter #30
I'll have to try. I swear I've rebooted mine with the 10-second power button hold since the update.
Gadgtfreek
Mobile, Alabama
Thread Starter #31
OK, two things. The Dark Mode comment was a helpful win. I had CarPlay on dark, but didn't realize the Ford software had dark mode too. Much better.
Second, I just went to grab some burgers and grill stuff, held down the power button for 10 seconds, and rebooted the software while riding down the road. I'd pull the battery cable for awhile and go that route.
Rky Mtn ST
Colorado
2025 Rapid Red ST
#32
After mine updated, I noticed the heated seat icon changed.
Marietta, GA
2025 Ford Explorer ST 4WD
#34
I too am disappointed in the update. Prior, I could easily adjust airflow to windscreen as well as various passenger settings. Now the only defrost setting in MAX, which is not what I want most of the time.
I would like to revert to the previous iteration. But know not if it is possible or how to do it.
New Albany, In.
2025, Explorer ST
#35
Gadgtfreek
Mobile, Alabama
Thread Starter #36
So weird.
Greenacres, FL USA
2025 Explorer ST and 2021 Mustang GT Premium
#37
You can only do a soft reset when you are stopped, and it no longer by holding down the power button but by tapping it a few times.
Gadgtfreek
Mobile, Alabama
Thread Starter #38
Got a notification today that an update will install tomorrow at 0100. Nothing about the ECU, so I am going to let it go ahead. I turned off auto update so I was allowed to review it first on the screen in the car, before telling it yes.
