Module breakout issue
Alberta Beach, AB, Canada
2018 Lincoln Continental
New member. I have used forscan for some time to check and clear codes but not for configurations. I have the latest version of Forscan and a recommended USB dongle.
I am now trying to configure the low tire setting in the TSP monitor section. I have watched several videos and there screens of Forscan show two lines for modules, one that says as built and one below that just shows the module. When they go to expand the module contents they use the second one not the as built. If I try to expand the as built I only get things like 7b7-01-01 and no contents. My question is how do I get those second choices. I assume that those second lines are what some have meant when they say use the English version not the as built.
Second question is that some videos say use the search function that they show on the bottom of the screen, I don't have a search bar.
I hope I am not starting something that has already been dealt with in this forum but my searches did not get results.
The section with the numbers only is the core module data. The section that is in text with drop down menus is a sort of "translated" version of the as_built data that ForScan prepopulates. Not every vehicle will have this for every module. Usually as forscan updates, this may change.
When a vehicle is new, you only have the core module data, so based on research you would go into the programming and change one bit of data. For instance you would change one bit of 724-01-01-A809-F400-xxxx to activate/deactivate something. This is what the spreadsheets are good for.
As more time goes on, and more research is done, ForSCan updates will create the other menu that gives you prepopulated drop downs that you can select.
Make sense?
F
Thanks for the reply. The vehicle is a 2017 lincoln so not new. Is there a way or setting to get Forscan to translate this data or do I just wait for the next update and hope. Is there a way to tell what modules are in the different 7B7-01-01 type sections.
I have another questions that you may be able to help. I see the spreadsheets in videos but I don't know how to get one for my car. I have downloaded the as built sheet from Lincoln but it is not a spreadsheet. It is more like what I have showing now in Forscan.
Thanks Again
Ah i understand now. The menu options just may not exist for your vehicle because not a lot of resources have been thrown at deciphering the hex code completely. Doesn't mean the option to change something isn't there. It just means you need to go off a spreadsheet to figure out what bit of hex code you need to change.
What model Lincoln is it? Depending on the model, the ford counterpart sometimes has the same data. For instance the MKZ and Fusion.
F
It is a Continental so not many built of sold compared to other models. It is built on the Fusion platform and I got a spreadsheet yesterday from someone who said that was for Fusion but when I printed it it says 2015-2020 F150. I am going to search today for a Fusion one and see if the numbers match what Forscan shows in the as built modules. Then I will have to learn how to get the as built sections to open for calibration. One step at a time for me.
F
Thanks, I got that one early this morning. Haven't been out to run Forscan yet to see in numbers match. Downloaded as built from Ford but can't open it. The file extension is .ab and I can't find an app to open it. Google says it is for Andoid backup and not meant to be read. I'll contact Lincoln today and see if they have a version that I can open.
I don't think i've ever attempted to read those outside of forscan. You would connect to a vehicle and load it, but do not write. I've then taken screen grabs and then disconnect (again..without writing) and go digest what the AB had for data.
F
I was looking for other programs that might have the breakout that I am missing in Forscan but nothing compares unless you spend a ton of money and I'm not sure they would help.
Going back to the car today or tomorrow and start playing again.
If I can only get into the as built is it safe to try changing module setting there?
