Hey guys!
Back with another update and we'll be diving deeper into this. To start, we understand that this part of the installation is challenging mixed with a tight fit, and variable tolerances between different vehicles doesn't make it any easier. So, to help rectify this, or at least help clarify the installation, we're bringing in a third vehicle for another test fit and to make an install video focusing on how to get through the tricky bits. I'll be sure to post up the video and updated instructions once we have them ready.
For those currently stuck on this install, something that our engineer wanted to relay was to try slotting these tabs in from the side, which may be easier than dropping them in from overhead.
I also wanted to note that these tabs are not critical to a proper installation. They were one of the primary mounting points for the OEM intercooler, but the size and weight of our's would be way too much for these. We added the tabs as more of a locator/temporary holding position while the main mounting points are snugged down. As long as the lower struts and three other mounting points are properly aligned it's not necessary to have these tabs fully inserted, and especially if it means damaging your OE radiator.
Thanks, guys, I'll be sure to keep you posted on what we find on our next test fit, and keep you posted on the latest installation info as it becomes available
-Nick
