Light battery appear
Hamza
Firefighter
Iraq
Explorer ST
Hi brothers...
I have Ford explorer ST model 22, I disable auto start/ stop by forscan and then I return to enable it, but appear problem after that, I diagnosis DTC U012D and light battery appear in dashboard but generator still charging battery with conventional mode!!!
How fixed this issues
Reenable auto start stop. Unfortunately, some cars dont like having the feature disabled. You’d need a tune or auto start stop eliminator device tp disable it.
H
Hamza
Firefighter
Iraq
Explorer ST
I want now to fix the charging from generator
Test
Put a volt meter on the battery terminals after you start it. If charging, the voltage will jump to around 13.3 to 14. If it still reads 12v after starting, charging system may have a problem.
