Hello all
C_L213
Salem, OR
I bought my 2020 ST on Oct 19 2025 aside from water leaking on to the passenger floor board scared I got a week after purchasing it . I love it
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
Welcome Aboard!!
Not saying this will be the answer for your specific situation. I have had the drain tubing from the sun/moon roof either become plugged or disconnected from the trough around the sun roof frame. That causes the water to come down inside the "A" pillar near the windshield and accumulate on the floor mat below the glove box. I have also seen leaks generate from cracked, dried out or otherwise unusable rubber sealing material around the windshield. Troubleshooting will drive you nuts. Hope this helps.
C
C_L213
Salem, OR
Thanks for the info. I got it solved looking thru threads on here I came across one that said they started having the same problem after they had their battery replaced. And sure enough mine had been replaced also . It was the cowling not seated correctly..
Congrats and welcome! The loose cowling is what usually causes leakage, so glad you found it.
