H&R install and first impressions
Westfield, NJ
2024 Explorer ST
This topic has probably been discussed many times over but I would like to add a few details that I discovered during install.
1. Rear springs:
I only had to take 1 bolt off to remove and install rear springs - sway bar link bolt. I used the jack to compress rear spring and then inserted inside coil spring compressor, once I lowered the jack spring simply came out. To install the replacement, I compressed it first, popped it in, jacked it up and removed the compressor. You don't even have to take the wheels off if you have a lift.
Total time for both rear sides: 45 min.
2. Front springs:
I installed over 100 H&R springs on various vehicles and never seen them being installed upside down unless they call it for it (Supra). I went ahead and emailed their service dept and got a confirmation that lettering has to be upright, top of the spring has to sit flush and not the bottom. I confirmed it with the stock spring and it also tilts to 1 side.
Total time for both front sides: 2 hrs and 2 beers
Car dropped about 1" in the front and 1.25" in the back right after install. After 50mi drive they settled in around 1.25F/1.6R. Will update after 1000mi.
Ride is significantly better, more planted to the road. Not harsher at all comparing to stock. It absorbs small road imperfection way more predictably.
- internal spring compressor
- stock vs hr front springs comparison
- stock ride height
- hr after 50 miles
DarkgrayST
Austin Tx
Great info!
Sacramento, CA, USA
1. Rear springs:
2. Front springs:
- spring pops right out View attachment 26070
View attachment 26071 View attachment 26072
- stock ride height
- hr after 50 miles
Nice write up, I will have to get an internal spring compressor if I ever switch out my H&R's. You're ST looks good!
Correct me if I’m wrong, but just because lettering on a spring is upside down doesn’t mean the spring itself is installed upside down. I know a lot of people had to install the spring with it seated correctly and the spring in the correct orientation with lettering upside down. Maybe just an manufacturing mistake, after all it’s just lettering?
Correct me if I’m wrong, but just because lettering on a spring is upside down doesn’t mean the spring itself is installed upside down. I know a lot of people had to install the spring with it seated correctly and the spring in the correct orientation with lettering upside down. Maybe just a manufacturing mistake, after all it’s just lettering?
The lettering is irrelevant if the spring has different ends. Just read the rubber pad the spring sits on…match the new spring to the old indention and all will be well. The car will quite literally show you how to orient the coil.
That’s pretty much what I was thinking, just wanted to confirm.
This is what I recall when I did mine. It was obvious which way to orient the spring.
nikolai9956
Westfield, NJ
2024 Explorer ST
Regardless of the lettering, when you seat the spring onto the strut assembly, it will not sit straight up and will try to tilt to one side. This is normal because top plate is what has to be flush and straight and no the bottom. Some people get confused because the spring tilts sideways. If you sit it flush and straight on the bottom, it might cause slight clanking noise when fully extended, as per H&R email.
SmittysST
SOCAL
2023 FORD Explorer ST
Great write up! I like the look with the HRs and your spacers!!
22SporTsploder
America
22 Explorer ST
1. Rear springs:
2. Front springs:
- stock ride height
- hr after 50 miles
Curious to know how once you jacked up the rear wheel you were able to fit the spring compressor in the between the compressed spring? How would there be space to insert the internal spring compressor? I would think you would have to insert it from the top or bottom or the opening of the spring which looks to be inaccessible?
nikolai9956
Westfield, NJ
2024 Explorer ST
Correct. I inserted the retainers while it was uncompressed. Then compressed it and inserted the bolt from the bottom.
22SporTsploder
America
22 Explorer ST
Okay so the whole on the bottom is big enough to fit the spring compressor rod/bolt! Thanks I'm about to order the internal spring compressor from Amazon.
nikolai9956
Westfield, NJ
2024 Explorer ST
Thread Starter #13
I used a cheap one from Amazon as well. Once you take the spring out, I recommend using better quality external compressor (the one you'll use for the front) to release the pressure off the spring. Then repeat the process with the replacement spring.
22SporTsploder
America
22 Explorer ST
Very helpful thank you!
