- Messages
- 91
- Reactions
- 161
- Points
- 27
- Location
- Alberta, Canada
- Vehicle
- '25 Explorer ST & '24 F-150 Raptor
Since it's Friday, I figured, why not post this one too! Another question I got asked was, "Can Global Windows Close be enabled?" Answer is YES! The video attached shows Global Windows Close via keyfob!
**Global Windows Open should be enabled by default as standard. Check your vehicle settings on your infotainment screen in the "Windows" section. Toggle the "Global Windows Open" on!
The following will need to be changed:
1. Connect your Explorer to FORScan.
2. Go your BdyCM (easy way, not as-built way).
3. In the search bar on the top left, type in “Approach Detection” (without quotations).
4. Change the following below from Disabled to Enabled:
5. Then change the following 2 modules below in "as-built" way, to enabled:
6. Disconnect the Explorer from FORScan and turn off your Explorer.
GLOBAL OPEN: Click and click-hold the unlock button until your front 2 windows are rolled down.
GLOBAL CLOSE: Click and click-hold the lock button until your front 2 windows are rolled up.
--You’re done! Cheers!
Link to video for Global Close, since I am unable to upload a video to the thread: Global Windows Close - '25 Explorers
Works perfectly on 2025 Explorer Active, ST-Line, ST and Platinum!
- Global Close (change from Disabled to Remote)**
- Global Close - Vehicle
- Global Close - Initial Value
- Global Close - Personal 1
- Global Close - Personal 2
- Global Close - Personal 3
- Global Close - Personal 4
- PDM -> 741-06-02 -> xxxx-xxx1-xx--
- DDM -> 740-06-02 -> xxxx-xxx1-xx--
- Show All
