Gear Like Noise While Driving (No matter turning left or right)
STBlanco
Georgia
Good morning, was driving my 2020 ST to work this morning and pulling out of my neighborhood I noticed a very quiet subtle noise coming from the passenger front, so quiet I had to actually listen for it but it was there. It sounded as if gears were touching together and rolling, or a better explanation would be if you put something in the wheel of your bike when you were a kid like a playing card. Same thing as if it were on a bike, I accelerate and the noise would speed up, slow down and the noise would slow down only could hear it between 15-50 mph, when I got to work I took a look and didn’t see anything out of the ordinary, nothing caught in the wheel or brakes, no flung up fluid, nothing dripping, I’m concerned if it’s the front drive unit or “diff” being dry or a bearing going bad? Maybe a CV Axle? I’m a forklift mechanic, so I don’t see many things as would be on these newer cars, but it’s not whining, growling, screeching, and can’t hear anything when I roll the windows down and drive, just sounds like it’s in the floor board, driving doesn’t feel weird or funny neither does braking. Any ideas? Going to check it out on my lunch break just curious if anyone else has experienced this.
S
STBlanco
Georgia
I should also note that there is no clunking, no pops, no slipping, no wobble in the steering wheel, also another way to explain the noise is a roller coaster going up the constant and consistent “click click click” but it follows the speed of the wheel, as stated when I accelerate or slow down the noise follows
The clicking is a result from improperly torqued axle nuts.
S
STBlanco
Georgia
During my lunch break I climbed under and checked the front differential fluid, looked black, put some fluid in it and it wouldn’t go away. (It took a little less than half a quart so it was very low) Forgot about it and left to go home and it went away MOSTLY, not all the way, can still hear a creak, pops, and still as stated before just not as loud, either I have a leak somewhere, or it’s never been serviced, I just noticed it this morning it could’ve been making the noise longer because it was super faint this morning, only noticed it because I wasn’t playing any music, get home sharp left turns, sharp right turns in the cul-de-sac and I hear no popping, no signs of a CV Axle, should I check the Axle Nuts? Where should I go beyond this, probably going to drive my F150 to work tomorrow to keep stress off the explorer until I can get it sorted
It’s the axle nuts most likely.
S
STBlanco
Georgia
Over tightened or starting to loosen? I apologies if this sounds like a stupid question I’m not familiar with CV axles or AWD systems, been learning slowly with this car I’ve had it almost a year, put 20k miles on it so far only had to replace the evap solenoid and oil every 5-7k miles, I’m used to my old F150 and forklifts
Los Angeles, CA.
I'm in the same boat man. I first noticed it a week ago today. Driving home with the fam on the highway low music while decelerating around 60mph down to about 40mph i heard that noise that i would also describe as a card on a bicycle wheel. Accelerating up to 70-75 it turns into a whistle/humming noise. I'm always blasting music during the week on the commute to work and back and I only take the streets since it's relatively close. So the fastest I probably go is maybe 40-45ish but with the music so high i most likely didn't notice it. Jacked it up check engine oil but it was good level wise. Then checked all the panels/trays on the underside and everything is pretty tight down there. The noise does not appear while revving in park/neutral so it's not knock. I have heard a click every now and then going in and out of the drive so maybe driveline related.
I've read how to "test" for a bad wheel bearing so i'll most likely do that tomorrow. I'm out of warranty (2020 ST with 35K miles). Afraid to take it in to the dealer and get charged an arm and a leg for something I can probably do myself.
Have you found out what's wrong with yours yet?
Depending on when you bought it there may still be power train warranty. It it good for for 5Years/60K mikes.
Polizi212
Had a noise on my 2020 ST that sounded very much like a card on spokes while driving. the shop found that a metal tag on one of the Axels had come off on one side and was slapping something under the card. its all fixed now, but I have to go back for a Camera recall/warranty and my FADA is leaking at the seal! so yeah not bad for 63000 miles i guess and I have the extended warranty so that's good for me.
Los Angeles, CA.
So I lifted her up as soon as I got home from work. Did the wheel Bearing check and there is no play on X or Y axis. Spun the front wheels by hand as fast as I could and no noise. I did the rear and sure enough I can hear it back there. Now the real kicker is that it seems that the actual noise is coming from the rear diff. Hate taking her to the dealer but I really don't have the time this week with my dad and wife's bday Thursday and Friday. Gonna let them know to take care of the 3 recalls while they're at it.
Iowa city
2021 Ford Explorer St
Did you get any resolution on this from the dealer? Having the same issue with our ST currently.
