FORScan - Basic Info and Getting Started
Embarking on your journey with FORScan, feel free to add any insights to aid fellow enthusiasts.
Here's what you'll need:
  • A Windows laptop
  • FORScan software along with an extended license (obtainable via a free 2-month trial upon registration)
  • An OBDII ELM adapter, preferably with a HS/MS CAN switch to access all modules.
  • Consider employing a battery tender/maintainer during FORScan sessions to prevent draining your vehicle's battery while the ignition is on.
Navigating FORScan:
  • Prioritize safeguarding your OEM module configuration by saving it before making any alterations.
  • Adhere to all setup and editing prompts diligently.
Useful Resources:
Bridgewater, New Jersey
STfan, Great ! please everyone keep this going !! I bought a 22 st and constantly read stuff people have changed and adjusted with forscan. I so want to do alot of the things I read they change.The problem is I know nothing ,zero,ziltch, about how to use for scan and it seems hard to figure it out by the things I read when I see people asking for the paper forms with the info you need to change things. Plus truth be told I am almost computer illiterate so when someone says just go into ur bios or some other crap ,I'm olut . I have no idea what you mean... So for all of us that don't know the difference between the properties of a computer and the properties our houses are on , please keep posting for us !!! THX
powerboatr
Köln, Germany
Best regards from Germany!
can you tell me why there is no APIM in the "Livnitup"
Thank you and have a good time
Oli
Welcome to the forum.
powerboatr
Oli
i sent an email
i have no idea, had not noticed until now
will follow up
powerboatr
I posted it in the forscan thread. New updates
San Francisco
2022 ST
What is "The Forscan thread", and is it pinned somewhere?
(Think 4th dimensionally. If someone finds your post, how do they access what you reference)
powerboatr
Sorry if this is a dumb question, but is the 2025 able to be done on Forscan yet?
Yes..
Tim Isyk
Meriden Connecticut
2021 Ford explorer ST
Go on WOOT and get a cheep $100 computer loptop and install FOSCan, have a nerd set it up for you and your done change what you need.
New Jersey
2017 Grand Cherokee
Peteroo
Milwaukee
2023 ST
that should work and if not it’s free returns
I got a prompt that said something like the adapter may not have access to all things. The bdcm didn't have engine enhancement info, so I suspect i need a different one.
Also, what's the Lincoln experience that's listed. Sounds fun
New Jersey
2017 Grand Cherokee
wondering if maybe you had the switch on the unit in low speed vs high speed? If not maybe it isn’t compatible I know they say a lot aren’t so I bought the recommended one.
Happy thanksgiving!
Peteroo
Milwaukee
2023 ST
picked up a obd ex and same thing. in the coded form i only get 726***** codes and nothing in the easy bdycm. could i have another weird connector, or car or am i looking in the wrong place?
Peteroo
Milwaukee
2023 ST
Got it figured. Needed to delete old file for car and rescind all the config files
