Exhaust
Breedog03
Houston
‘22 Explorer ST
After reading some on the topic, it is my understanding that upgrading the stock exhaust really adds nothing to the vehicle. Is that the general consensus? The only thing it adds is a different sound is what I’m reading.
I thought about adding exhaust because my assumption was that it would add to mpg and h/p. If that is wrong, I will spend my $ elsewhere.
I have a tune and intercooler, what other upgrades can improve the h/p or mpg?
Depends how far down the rabbit hole you want to go and what level of tune you plan on putting in. There are some enhancements to the items you plan on adding like a CAI, colder plugs, and downpipes. Not sure if any of this will add HP. Again, this is based on the tune you plan on going with.
High flow catted downpipes will get you 20ish HP at the tires. The cat-back just adds the sound most people want. SPD, FenFab, CV Fab and Whoosh Mororsports all make good DP’s. For the money you can’t beat the quality and sound of Thermal R&D for a cat-back.
Edmond, OK
It adds sound, but more importantly gets rid of those ugly fake exhaust tips. I could not stand looking at those anymore. The Thermal 2.5" sounds amazing and the quad stainless steel tips look the part.
Agree. I originally went polished but then I had them powdered gloss black. The sound is a great compromise. Not the in your face of my youth. Little rumble and moderate sound unless you get on it.
Also a thumbs up for SPD catted downpipes.
B
Breedog03
Houston
‘22 Explorer ST
Thanks for the input. I’m sure the down pipe install costs a pretty penny. I will definitely look into it. As far as the exhaust goes, the thermal r&d “3 exhaust with black tips look clean, but $1800 isn’t cheap.
No exhausts for these is cheap. You have to look at what all you get also. Some like Thermal include the mid pipes with new flex section while some like Borla do not and retain the oem flex sections which in all likelihood will fail at some point.
Jacksonville, FL, USA
I just put on the thermal 3” last week. It’s an easy install. Sounds fantastic. You will not be disappointed. I got them from whoosh for $1680 with free delivery.
B
Breedog03
Houston
‘22 Explorer ST
Did you install yourself?
MIB
colorado
I have a 2023 and the thermal 3" is what I am looking at but I don't know what else is needed? (new to this) What all did you have to purchase for your set-up? Thx.
Nothing. It comes with everything you need.
MIB
colorado
LuxST
South Carolina
What’s the difference between thermals 2.5” and 3” besides the obvious? Benefits and cons between the two.
2022 Ford Explorer Platinum
I believe the 3" gives a deeper rumble and is a bit louder. I have the SPD downpipes with the 2.5" which sound amazing, but I like the deeper rumble of the 3" and will likely be swapping them in the somewhat near future. All in all, it's likely a personal preference.
