Eibach 30mm spacers
jwalkerftw
EMT
California
2021 Ford Explorer ST
Anyone running Eibach 30mm spacers? If so did anyone have an issue with not having enough space with their wheels cut-outs around the hub? Are all cut outs the same on all ST OEM wheels and deep enough to fit the 30mm Eibach spacers without having to trim?
Combatvet
I believe they still need to be trimmed.
The 30mm spacers work fine with no trimming…that’s the whole reason to get them.
Combatvet
Good to know I'm not always right.
jwalkerftw
California
I've heard some saying to get 30mm Eibach spacers front and rear with rear camber set to -.5° if you want near flush and no stud trimming. Is that true? Also if the rear would to be set to -5 degrees, would the tires wear down unevenly?
Farmers Branch, TX
No uneven wear and 30mm spacers with that camber will poke a little, but very close to flush.
