Carroll Shelby CS10 (20x9.5, 37mm offset)
Would it be even more tucked than stock?
It would be pretty much the same, maybe a quarter inch less tucked but it’s not going to be a noticeable difference.
jwuonog
Jessup, MD, USA
I'm OK with it being the same. The stock fitment never really bothered me. It's my wife's daily.
I called Holley and confirmed that the load rating is 1929 lbs per wheel.
jwuonog
Jessup, MD, USA
I went ahead and ordered. I also ordered a 7mm spacer and hub centric rings. Here's the only pics of the wheel on a car that I could find:
I also got some General G-Max AS-07 in 295/45/20. It's pretty close to the same diameter as my OEM 21s, so hopefully it doesn't look too silly on the stock suspension.
Keep us updated with pics when it comes in.
jwuonog
Jessup, MD, USA
They're here! 7mm spacer and hubcentric ring coming later. That should effectively make the fitment the same as a +30 offset, right? This is my first time venturing out of the norm and buying a wheel that nobody has tried.
I also ordered a set of OEM Motorcraft TPMS sensors. The part number is JX7Z-1A189-C, TPMS-60. I have a set of Amazon ones that supposedly work, but I'd rather not deal with the headache.
I should be able to get a pic of the wheel on the car tomorrow (no tire mounted yet).
Well that would make it +30 offset but it wouldn’t make it near flush at all.
jwuonog
Jessup, MD, USA
They came, and like a kid on Christmas eve, I couldn't wait until tomorrow. So here's some night time pics.
jwuonog
Jessup, MD, USA
Here is the spacer and hub centric ring. Did I install it correctly? Is there anything unsafe about using these?
I imagine the heat will make them get stuck to the rotor. Should I put some antiseize on it so my next brake job isn't awful?
Nothing unsafe about those as long as they’re not too big. I’m actually very curious to see how these look. When are you getting wheels mounted?
jwuonog
Jessup, MD, USA
Thread Starter #15
Probably not for a few weeks. I ordered some OEM motorcraft TPMS since I don't trust the Amazon ones I had. Then I'm going to Cancun for a week. (There goes my mod money)
