Best Oil Catch Can
I always thread mine off and empty it once a month. Not very much in there usually. Didn't like how full it got when I went to each oil change so just when I remember each month.
Same here. Only get about a half inch or so in the bottom. But I also know if I am feeling frisky for a week or two it definitely builds up more.
Long Island, NY
I apologize if I am hijacking this thread, but how do you clean the Mishimoto catch can? Is the canister two piece where you screw off the bottom half?
Be aware, if you should develop an oil leak your dealer will blame it on the catch can and not cover it under warranty. Remove it before service.
Caster
Catch cans won't make an oil leak that I am aware of. If a dealer wanted to fight me on that, I'd say go ahead and try proving your case - Magnuson-Moss Warranty Act
Long Island, NY
I didn't say it would cause a leak. I have one with no issues. Is it a fight you want to have or take 4 minutes and remove it. Aggravation avoided.
OgRoar
PNW
This looks VERY nice. Phenomenal work. Are you planning on selling them?
My 1 suggestion, and I would be surprised if you haven't already planned for it, is to make the mounting tab end either rounded or just round the corners. Would make the fit and finish 100%. I assume this is still a prototype.
Louisiana
Hey everyone, I'm new here. Just took delivery of my ST last week. It's a '23 with ~10k miles on it. There is currently no catch can installed. I've got the itch to do SOMETHING to the car (y'all know how it is) and it seems like this is a pretty inexpensive, straightforward, and simple (looking at the J&L) install.
Here is my question though: The car's been running for 10k miles already with the stock setup. Presumably, there's been a fair bit of oil already deposited to the intake. Is this something to worry about? Oil catch cans are a new concept to me. I understand the premise of them, but I'm curious if any benefit to be had with them has been diluted for me given the use already on the vehicle.
Thanks
Long Island, NY
Thanks
Never to late to start. I installed my J&L at 35,000. I empty it when I change my oil every 5,000 miles. I also have the extension cup installed incase I forget to empty it.
Caster
hfrog355 - Not all turbo engines expel a lot of oil. Some much more than others. For example, my 2018 twin turbo Fusion Sport has had a catch can on it since day one of my buying it brand new. I have yet to ever see much more than half a teaspoon of oil in it at best and it has 65K miles on it now. Some engines are tighter than others and you won't see much oil from a tight engine. Adding one at anytime doesn't hurt.
Thanks
Welcome to the forum.
Louisiana
I guess I have this question too: why are we porting air from the crankcase back to the intake? Why not just vent it out of the system altogether?
The only other performance engine I've had was a 370z and I don't remember catch cans being a part of the conversation. I never dabbled in forced induction though. I take it that this isn't really an issue with naturally aspirated motors?
Caster
All engines recirculate crankcase air (with oil mist in it) through the PCV valve. The biggest issue with the 3.0 liter engines in the ST's is that they are direct injection only and not port injection or a combination of both direct, and port fuel injection. Port injection sprays fuel directly onto the back of the valves and keeps them clean from carbon build up from the recirculated engine crankcase air that contains the oil mist that many of us are using the catch can to seperate the oil from the air. The oil mist collects on the back of the valves and causes gumming and sticky valves, that over time, may not close completely and seal off. Oil catch cans eliminate (or greatly reduce) that and of couse since the air and oil is seperated before the intake, everything else downstream (intake, inner-cooler, turbos) remains much cleaner and uncontaminated.
Louisiana
That makes sense. Thank you.
So, I guess my last question here is - why aren't manufacturers doing this? Seems like a rather easy thing to take off the aftermarket's hands.
Some do. All about cost imo. My wife’s Mercedes has a stock oil separator on it. Most do not.
Caster
It is a cost and convenience issue and its not an absolute necessity.
Most people don't want to be bothered with needing to drain a catch can. Its more work.. Some people call oil catch cans snake oil fixes or add-on's. Do lots and lots and lots of engines function just fine without oil catch cans - yes. Do some have failures or issues because they do not have an oil catch can - again, yes. It is purely a personal choice and for some it is called cheap insurance or piece of mind. It's all up to the individual.
Imo if you keep your cars for a few years and trade them then it’s not worth it. If you keep your vehicle for 100k or 200k miles it is definitely worth. Eventually you will have to have the valves blasted with walnut shells to clean them if you have a DI engine. That can get pricey but does a fantastic job of cleaning. If you run a catch can or separator you can usually greatly extend the time before buildup affects performance.
#36
Why would you vent it to atmosphere? that completely defeats PCV and creates a vacuum leak.
Rapid Red Explorer ST
#37
Just an fyi. Over a month I did two long road trips of 2500-3000 miles each. Lots of playing during the drives. When I got home the catch can was 3/4 full. I was mildly surprised. Never get much in the can if I’m driving normally but apparently lots more when you are pounding the throttle a lot. Glad that oil is not voting my intake!
Canby, OR
How does it defeat the PCV? All the PCV does is allow the pressure built up in the crankcase to escape. Normally it's vented back into the intake, "with all the oil vapor"! Instead, it's vented to the catch can, where the oil is seperated and captured, then out to the atmosphere. I'm sure there are check valves to prevent a vaccum leak!
#40
It sounds like you don't understand how a PCV system works. Do some research and it will make more sense.
