2026 rear sway bar replacement
ARC
Oak Lawn, IL, USA
2022 ST Black
What's up guys let's get some input on this debate.
I ordered my new 26 from a 22 model.
I am putting together my mod list and am thinking on changing some things.
First is Eibach springs again just like on the old one, but I was thinking of just keeping the stock sway bar.
I mean after its lowered does it really matter that much as I'm not taking quick corners just concerned with 0-60 1/4-mile times.
I'm keeping my tuner device SCT and tuning with Matt at Gearhead again and tuned for E50 but am thinking of keeping stock intake instead of reusing the AFE intake.
I learned a lot from this forum and found that some mods just aren't worth the money and some of course are needed like intercooler/tune etc.
If you’re concerned with 0-60 and stability I find these to be 100% necessary:
Rear swaybar set to firm
Steeda rear subframe bushing braces
FenFab billet vertical links
Steeda adjustable toe links
ID Speed diff brace
Adding those parts makes a night and day difference.
ARC
ARC
Oak Lawn, IL, USA
2022 ST Black
ID Speed diff brace
The 22 has a AWR brace with the JXB bushing insert. I also have the Steeda subframe inserts but feel like those really added to a rough ride.
ARC
ARC
Oak Lawn, IL, USA
2022 ST Black
I'm doing the JXB insert again, but not the subframe bushing inserts.
Do you want good 1/4 mile times or a soft ride? If you want the best times, you’re going to have to firm things up. If you want the best ride, you’re not going to have the best times.
If you are ordering a 2026, you will undoubtedly be getting one with a gas particulate filter. I wonder what impact that will have on aftermarket tuning. Is it even worth having a tune?
