2025 Towing Capacity
usna2k
Chesapeake, VA, USA
Mostly just commenting - I was disappointed to see that towing capacity has been downrated to 5,000 lbs and only class III hitch - I would not be able to tow my current Airstream with that. I really was looking forward to the upgraded interior on this one. Guess I will keep my 2022 for now.
i wouldn't be surprised if the new ST is slower. Seems like Ford is going all in on the 3 bolt rear subframe and the "retuned" transmission gives me pause.
88lx50
Firefighter
NYC
The 2025 has the 3 bolt rear?
WI
My 2020 has a class III hitch, still rated at 5600 lbs tow capacity. So the drop to 5000 lbs is not from the hitch (class III hitches can support 8000 lbs).
The towing capacity reduction is one of the first things I noticed about the 2025. Really curious as to why the downgrade in towing capacity if they are carrying over the same engine & drivetrain with no changes minus the trans. calibration change (whatever that is). I have a 16' tandem axle, 4-wheeler and dirt bike trailer that when fully loaded including the weight of the trailer is right at 4,400 lbs. . My 2022 ST I traded in last summer (due to a storm that covered it in hail dents) pulled my fully loaded trailer just fine. I liked being just under the general rule of pulling no more than 80% of the maximum towing capacity.
A week and a half ago I ordered a 2025 ST to replace my traded in ST. Towing my fully loaded trailer with it and with the lowered towing capacity will now put me only 12% under the max. . It still should be fine but not as ideal as the previous ST's capacity.
L33der
Pennsylvania
17 Explorer, 20 Transit, 24 F150, 25 Explorer ST
Could it be a lot of stuff is now standard on these? I wonder if the added weight of everything makes the reduction in towing capacity? I wouldn't think there is 600lbs of added weight though.
My thought which is purely a guess is that the previous models may have been overrated so the new tow capacity number is a correction from that. If Ford was getting abnormal warranty claims associated to towing, that's the easiest solution if they are unwilling to change/upgrade componentry.
L33der
Pennsylvania
Sounds like something Ford would do. SMH. Looks like a "Stiffy Diffy" or similar support bracket will be added to the list of mods if this holds true.
