2025+ Ford Explorer Spreadsheet now available!
Palos Hills, IL
2025 For Explorer St
#61
I had no issues getting the amber DRL's to work on my 25 ST. There is a more detailed thread that I will link here. Take your time, follow the instructions and you shouldn't have any issues. This thread addresses using the ambers at night as well, but it is also a more thorough guide to getting started. It worked for me when I followed the instructions. To get you amber DRL's working during the daytime, you only need to follow the instructions under "STEP #1". The rest are OPTIONAL instructions explaining how to get your ambers working at night with fog lights only.
https://www.explorerst.org/threads/now-possible-amber-drl-led-bars-at-nighttime.8974/
I'll post a picture of what im seeing on my laptop.
SoCal
#63
Looks good. Did you also check this?
When you are finished, you will need to have your vehicle in Drive to see the results. You will not see ambers in Park. Have someone outside the car check for you or pull up to a store window in Drive to check.
Palos Hills, IL
#64
No, I didn't do lines 21-01 or 27-02. ‍
I'll have to get to this another day. Today is gonna be a late one for me.
Palos Hills, IL
#65
I honestly didn't think that would apply to me. Smfh. Thank you for pointing that out to me.
NJ
2020 Interceptor
#66
Damn,
Im hoping I can get some help for my 2020 Interceptor to keep the DRLS Ambers on during the day and the low beams off until night time?
I can't get it to work just yet.
I also just learned that the Ambers have 2 different brightness levels!
Id like for those to be full bright in day and at night. Currently they are bright in day and dim at night or when turn signal is activated.
Palos Hills, IL
#67
Made no difference.
svache
Hawaii
Thanks for the hard work on this guys. I got my 2025 ST (job 3) this past weekend and really needed to make some changes to make the car more "mine" lol. All went perfectly fine so far. It's kind of unfortunate that the Auto Start/Stop function isn't tackled for the 2025 yet (not counting the eliminator). I can confirm changing the PSCM 730-03-01 setting mentioned elsewhere didn't do anything for me (oddly enough, even though I only changed the 10th digit from 2 to 0, digits 11 and 12 were also changed after writing the code, not sure how that happened, I know it wasn't me). Hopefully someone will be able to tackle that one at some point :)
SeeMak
Houston
2025 Explorer
#70
Hi,
I need help disabling Pull Drift Compensation (PDC). I change one of the "F's" to a zero but it wouldn't take. Any ideas? The steering in this car is driving me bonkers and I highly suspect this as the culprit.
New Hampshire
2025 Ford Explorer
#71
Below is the link to the updated FORScan changes that is currently available for our 2025+ Ford Explorer and applies to all trims for those who don't have an ST. This one is for us, which helps compile all into one.
LINK: https://docs.google.com/spreadsheet...bxZh92wdcE/edit?gid=1931803578#gid=1931803578
I've been digging through the spreadsheet looking for the right place to turn on my fog lights all the time. Thinking to turn them on with the DRL's, is the correct spot to do this? Fog DRL As Built.jpg
Alvin41
Missouri
2025 explorer platinum
#72
im trying to find spreadsheets for navigation in motion for 2025 explorer platinum. thank you.
rpd189
Chicago
#73
Can we get mirror reverse?
#74
Have had a few people try this, a lot still had FENG still there even with the Propulsion change via FORScan.The issue is that the strategy--Ford somehow combined the FENG and ACM (Active Noise Control) which blocks out the exterior noise when you drive. It's complicated buts till working on it (I'm currently on vacation till August 2).
Hey @Nightshade, hope everything is going well for you. Checking in for any progress on removing FENG. I have a Job 1 and seemingly still working to remove this feature.
