'2020- Current Explorer / How To Manually Open Liftgate Latch:
katmandude
PA
Before we start there is a very important obstacle you might want to consider:
IF you ever have to do this task, the 3rd row seats in the up position will make it almost impossible, as they will only power down with the liftgate OPEN (for your safety of course!).
Or else you will have to contort your body flopped half upside down over the seats confined there with a lighted mirror...Good luck !
A dealer can computer force command the seats down but don't count on them knowing how to open the latch...my dealer techs were clueless.
Afterwards, I did find in a 2022 factory service manual that shows image how to manually open the latch IKEA furniture style so...
First and foremost make sure dash fuse #8 and under hood fuse #41 are good ...and seated (all this could of been avoided, my #8 fuse simply was not making contact!)
Here We Go:
#1 There is a removable trim panel on the hatch panel at the latch. Pry it out.
#2 Locate the Cinch Pin thru the hole in the hatch and press it in until it bottoms out, then release it.
This mechanically releases the motor from the latch...
#3 Locate the Manual Latch Unlock Lever thru the lower left slot in the latch boot (yes there is an actual slot there).
Insert pick or small screwdriver thru boot into the lever, put pressure on and slide it to the LEFT (passenger side), and at the same time PUSH OPEN THE HATCH
Note: The lever is spring loaded so it will return back to locked if your tool slips off
Here is the motor/latch assembly cinch pin depressed without the hatch door and latch boot in the way...
and a clear view of the release lever directly below it.. see the tiny slot in it's right side
And the pick inserted in that right corner of the lever
The lever held in the (left) unlocked position
Thank you, good info that no doubt will come in handy.
I've seen a lot of people ask this question but never seen an answer to it. Awesome write up!
23 Explorer ST
Thank you!
saljr606
Ny
2023 ford explorer xlt
Thanks for this
Question I had the same exact experience with broken glass
Did you end up having to change any parts or just clean it out
katmandude
katmandude
PA
Thanks for this
I re-installed it but it started to buzz before partially releasing to a full release so I replaced it.
In other words it wouldn't just pop open cleanly.
So, perhaps the glass crumbs did do internal damage
saljr606
Ny
Thanks for your help
Much appreciated
did you remember the part number
I would rather order it now and then take everything apart
If not thanks for the help
katmandude
katmandude
PA
Much appreciated
Sure! Here you go..
Ford OEM Part #: FA1Z7443150B
I took a chance with this 1/8th the price unbranded compared to OEM. Glad I did, can't tell the difference physically and works like a champ. Time will tell but now we know how to get to it if it croaks down the line...Easy swap out
https://www.amazon.com/dp/B0BV186B6C?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
saljr606
Ny
Thank you very much man
You saved me a lot of time with all of this
Boston, MA
2020 Ford Explorer
This is super helpful - I'm trying to follow the instructions here but when I go to open the hatch it won't budge even with the lever to the side - any ideas what else to do on this? I had just installed a new lift gate and it worked fine for a couple days but now it's locked tight for some reason
katmandude
katmandude
PA
Thanks for this
I believe glass bits did trash the unit, it became cranky so it got replaced, sorry for just getting to this I must have missed e-mail alert
katmandude
katmandude
PA
Very important...Does the motor / latch do anything like make a noise or attempt to open when you press the open button ?
Did you first release the motor from the latch mechanism by pushing in the detent pin, then slide the lever to the left?
Boston, MA
2020 Ford Explorer
Yes i can hear the motor try to unlock, the door moves just a little so the struts are pushing but it won’t open. I pressed the release as much as i could - it doesn’t latch or anything right just press and release and then on to the next step? I can feel the lever moving and i’m pushing on the lift gate at the same time really hard but nothing budges. Should I spray some lubricant into the latch or something?
