Leaking oil?
Glockman
Memphis, TN
2024 ST
Picked up our 2023 ST. on April 21, smelled buring oil on the drive home. Turns out it is the left side turbo oil feed tube. Finally got it into the dealership for warranty repair Tuesday this week.
I had a similar issue, but mine was apparently the oil return line on the passenger side turbo. 2024 ST on the 2nd day of ownership with 150 miles... Got it fixed after some frustrating interaction with Ford, but it kind of takes the shine off of a purchase like this.
Jose131
Fredericksburg, VA
FORD EXPLORER 2020 ST
Yes, you have the FADA leak. They won't care about the tune... it is a known issue. Definitely get it fixed before powertrain warranty ends. Try to get them to do the FADA TSB and not just replace the faulty O-ring.
I do have fenfabb catless downpipes as well. I can install catted downpipes before going to the dealer if thats a problem
shouldn't be a problem. Has nothing to do with the problem. Besides, the stock cats were flawed and you can just say you went aftermarket because of that.
South Palm Beach, FL, USA
Well, I am joining the leaking FADA! 2021 only 24K miles. Very slight as the film was just around the drain plug. I did check the diff fluid level, and it needed 6 oz. Maybe underfilled from factory but who knows. I will make an appointment with my dealer. I have only brought the truck in for recalls but they do a nice job. Al Packer West in Palm beach FL. The fill port T50 is on there! I am wondering if the major problems came from the oil leaking out to the point the diff failed. Still have 1 more year on the powertrain warranty so let's see what they suggest. I saw some posts about oil return lines. Just smell the fluid. Gear oil has a very distinct smell compared to motor oil. Taste, well, let's not go there.
Tommy
Drweldin
MIdwest
Can someone verify if the oil is drained during this service? Reason I ask, I am in the middle of an oil change (50K) and found out I have this leak, of course...Obviously if they are going to drain and replace the oil, I won't bother. I should be covered under Ford GOLD warranty I got when I bough it a year ago. Thanks guys
Yes, if they replace the FADA or if they just replace the O-ring of the FADA, they will spill most of front diff oil and will refill it at the end. Not sure if they do a proper drain and fill tho
Drweldin
MIdwest
Sorry, I should have been clearer. I meant the engine oil, not diff oil. Thanks
Zeush
I just picked mine up today for this issue. 2020 57k and PT warranty covered it. Replaced the FADA with intermediate shaft. My invoice says 6qts of engine oil.
Can call and ask to be sure.
Drweldin
MIdwest
Here's what I'm dealing with. No codes.
Grand Rapids, MI, USA
So Im outside my powertrain warranty, how bad is this bill going to hurt?
Can yo overfill it or will it run out of the whole when its full like the rear end of an older pickup?
Motorcraft® SAE 75W-140 Synthetic Rear Axle Lubricant. Not inexpensive.
Front differential fill hole is on the passenger side. Torx T-50 (+ breaker bar if it's never been opened). Just top it off slowly until it starts to dribble out.
Front diff fill hole. Remove passenger wheel. Follow where the axle shaft inserts. It's right in front of that.
St. Louis
Isn't there a TSB for this item? I believe maybe discussed in this thread.
If so, Ford should cover the repair.
Chicago IL
TSB does not mean it is automatically covered under warranty. It is just documented as a known issue and if the vehicle is under warranty, then it is covered. They will replace the seal only if it's just leaking and not throwing a code.
Zeush
Mine didn't throw a code, the tech doing the oil change noticed the leak. The service advisor ordered the intermediate shaft that day and said it was covered under the factory power train warranty. I also have an extended warranty covering me until 100k miles. He said it would have been covered under that warranty if the factory was up.
You have codes or just the leak? If just the leak, seal it externally if you are out of warranty.
Canby, OR
If you have to pay out of pocket it going to sting! I would push them on the TSB and try to get the FADA delete.
Chicago IL
The same thing happened with my 2020 ST. I went for an oil change, and they noticed a leak of some kind and told me to bring it back. I went on vacation and came back to an oil spot on the garage floor. I took it in, and they replaced the seal. It was covered under the powertrain warranty as well.
