Custom Intake Manifold
Houston
To everyone doing big builds, is there any interest in a custom intake manifold? Obviously heater core lines would have to be redone for clearance but I could build a really nice unit, even with integrated water to air intercooler. Even without that, slightly longer runners, higher volume plenum and using a GT throttle body could be massively beneficial. We could even do integrated port injection abilities using a secondary controller.
That would be awesome. Especially on big single turbo builds.
Interesting. Not likely to be a customer for one but I love the idea. Better flow is usually always a good thing. Is the air/water meant to supplement the air/air or eliminate it? I was never a huge fan of the air/water system in my 2011 Ctsv. Even after spending lots of dough, still could boil the loop on track days.
Following for sure. Hope you get interest!
If you could build one that uses an A/C evaporator core like the demon does that would be something worth pursuing.
Air/water intercooler is inferior in every way to an air/air cooler UNLESS- you have some way to chill the water below ambient air temps. As far as an intake manifold goes, the stock manifold doesn't have any glaring problems. Increasing the plenum size or changing the manifold runner length to affect port resonance is insignificant compared to upping the boost level.
Police ST
Chicago, Illinois
2020 Ford Police Interceptor
I came across this thread cause I’m literally looking for a bigger intake manifold lol. I’m kinda putting a list together of what I wanna do to my explorer
No need for anything of the sort and if there was Hellhorse would be the last place anyone would recommend.
