The ULTIMATE Dyno / V-Dyno Thread
Marinette, WI, USA
Holy crap!
Do you have a mod list on this ST?
In your opinion, could this power be made using E85 and be driven daily safely?
No there is not currently enough fuel system on the market.
Sent from my SM-S918U1 using Tapatalk
texas
Jessup, MD, USA
Does anybody have some settings to share for vdyno? I don't see the explorer as one of the options in vdyno 1.8.6.
texas
Here's the settings I used from info I found. It got really close to my actual dyno numbers. I was mainly using it to see the HP/TQ difference from tune revisions.
Jessup, MD, USA
Cool, thanks! I'm going to try these on mine. Was your Dyno above on 93 or E50?
Isn't the final drive 3.35:1?
texas
That dyno run was on E45. 3.58 is the final drive ratio.
Jessup, MD, USA
I looked up some captures of the Explorer ST on the Ford website from a few years ago, here's what I found:
Wayback Machine (archive.org)
texas
If you check your door sticker, you should find your axle code. Mine is 3B. According to the ford towing guide for the Explorer, that corresponds to a 3.58 rear axle ratio, non-limited slip. Also, they list the ST only as having the 3.58 with the 3.0 ecoboost.
3A = 3.31
3B = 3.58
3C = 3.73
https://www.vdm.ford.com/content/da...owing/pdf/2024-Ford-Explorer-Towing-Guide.pdf
#32
I'm sure that the 3.31 rear end was for the Platinum. The ST has the 3.58
That Ford Pro site also says it has a limited slip rear end which is wrong as the ST has has an open rear end.
Marinette, WI, USA
#33
Single turbo 800 awhp
Sent from my SM-S928U1 using Tapatalk
Wow! Impressive for a 3 liter motor.
