2020 Audio Control Module
MSF
EMT
New Jersey
My 2020 has a non functioning radio. Dealer says the ACM has failed and ordered a new one. Well it still doesn’t work. The dealer is perplexed and has been trying to get assistance from Ford engineers. My research has led me to believe that the new module needs to be programmed to my car before it will work. Can anyone confirm this to be true and if so how is it possible that the dealer doesn’t know this.
Could also be the DSP.
As far as programming, tis from the service manual:
ACM
The ACM requires PMI when it is replaced.
DSP
The DSP is a power amplifier for the vehicle speakers. The audio input signal comes from the ACM via the Automobile Audio Bus (A2B) cable. It may drive all speakers on a vehicle or share the speaker output with the ACM.
The DSP requires PMI when it is replaced.
Fatkid4life
Philadelphia
2020 ford explorer st
My 2020 Ford explorer st do the same thing been to the dealership 4x and they still do know what's wrong with it. And they changing everything they can think of. This my last ford.
M
MSF
EMT
New Jersey
Mine took 3 months for them to figure out the ACM and the DSP had to be replaced. Hope you get yours figured out soon.
George14
Hillsboro, OR, USA
I just took mine in for its first diagnosis as everything works, but no sound comes out. They couldn't find a true cause but "guessed" it was the ACM and quoted me $1000 to replace. Do you know what tests your dealers ran to narrow down the problem? Does the ACM and DSP have to be replaced together?
M
MSF
EMT
New Jersey
I think I paid around $400 for the ACM. My dealer was great through the whole process, they were as upset with Ford as I was. It’s been working fine since then.
