I noticed that I could only find a 6 channel version when looking recently.  Strangely enough, it doesn't look like the part number is different, only the provided harness.  Sadly, it doesn't look like they are discounting the device with the reduced channel count.
In any case, I'd think having 4 channels is really the most you'd need if you are going with an external DSP solution like you've spec'd out.
In this car if you use optical to a dsp you maintain a digital signal chain all from the HU to the processor. If you use a good dsp amp you’ll never even need an RCA.
- Show All
		 If the amp is a 10-channel, I need to figure out what channels go to what speakers. Or just run an 8 channel, a four channel and a mono to put each speaker on its own channel.
