lightweight performance wheels 20-21" ???
Las Vegas, NV, USA
I have to admit, we are accustomed to light 15-17" wheels for our other ST's (and 4 lug)
I'm searching for some decently light wheels that won't take 12-20 weeks to deliver
Any thoughts ?
BC Forged is delivering in 5 weeks or less. These are my 22x10.5’s from them at 27.4lbs 7C0A4FE3-CC46-40FF-9AD4-C355A3A70835.jpeg
ron@whooshmotorsports
Las Vegas, NV, USA
BC Forged is delivering in 5 weeks or less. These are my 22x10.5’s from them at 27.4lbs View attachment 1567
they are really nice and the weight is impressive for the size
I'll check out that brand, hopefully they have 21 or 20" too.
thank you
Get that exhaust to market then shop for wheels. lol
Las Vegas, NV, USA
best selection I've seen so far
we finally have a donor vehicle - 1st kit with mid pipes will be in August
super legit wheels, thanks for the suggestion
I'm going to grab a set
I’m gonna grab your exhaust too...especially if you do mid pipes as well.
You might consider +35 on the offset to push them out a little more.
Las Vegas, NV, USA
Not sure why I thought the ET30 would make them basically even with the fenders
I'll change that to ET35 is that's what you have which looks perfect
Mine is +30 but my wheels are 10.5 wide. And I wrote that wrong...should have been +25, not 35. That’ll push the wheels out almost 3/4”...the front will still be tucked by about 1/4”
Las Vegas, NV, USA
thank you for the clarification
since the wheels I purchased are only 9.5" wide we changed it to +20 which should look pretty good
El Paso, TX, USA
I'm going with Bora spacers front and rear to push them out a bit since i also went with 9.5" .
1/4" up front and 1/2" in the rear should get the job done .
New York, NY, USA
Enkei TSR-X - 20x9.5 are 23.6 lbs. Gotta be the lightest wheel you can get for a decent price and good build quality.
dolsen
Louisville, KY, USA
One of my 21” wheels and tires came in at 78.8lbs.
My 22’s were 63.3 mounted and balanced.
Wow... That's a BIG weight savings... 60 lbs over 4 wheels. I don't really understand why factory wheels weigh so much... only reason I can think of is cost savings. But I do not know what goes into wheel/tire development from and OEM perspective
Canada
at +35 what kind of spacer will i need to flush the wheels up a bit..thinking 1/4" on the rear should do it? are all spacers made equal or is there a brand to get.? (wheels are 10.5/22 w/305/35s)
El Paso, TX, USA
I would say Bora spacers would work fine.....at least that is what i am going to use .
